1967 AC Expansion Valve lines clamp - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1604
    Re: 1967 AC Expansion Valve lines clamp
    Nick the picture I posted for the duel clamp is a generic picture of a clamp that matched the description of the one the judge stated was correct for 67. I could not locate a picture of 67 AC car with the said clamp. Only the small black single loop design. Maybe the judge used his prior knowledge of what he thought was correct without consulting the manual
      Originally posted by Keith Brodbeck (60464)
      Thanks Grag. That help supports my case. But can someone answer me if the evaporator housing was assembled at St Louis or not?
      Keith -
      C60, Sheet D5 shows the evaporator assy as received from Harrison (item #8), with all parts noted with part numbers added at St. Louis. Same is true of sheet D6, which shows more parts added at St. Louis. Sheet E1 shows the installation of the high blower relay (item #6) and the blower resistor (item #4).
      Any time you see an item with a part number callout in the Assembly Manual, that tells you that part was installed at St. Louis.
