1966 caliper mounting bolt head markings - NCRS Discussion Boards
  • Keith M.
    Infrequent User
    • April 30, 2001
    • 27
    need some help...have a 1966 and would like to know what the correct caliper mounting bolt head markings are...I assume they were all grade 8...and I assume the fronts are threaded all the way and rears have shank and all bolts would use lock washers...thanks as I am trying to make sure all my hardware is correct and I have the judging manual and it dosent specify....thanks again
    • 43273
    Re: 1966 caliper mounting bolt head markings
    Keith-------
    The bolts have a raised perimeter on the head, 6 radial lines extending from the raised perimeter to the "O" in the center. The configuration is the same for both front and rear bolts. However, the front bolts were 1-1/4" long whereas the rears were 1-1/8" in length. The fronts have a short unthreaded shank; the rears are all thread.
    A thick split lockwasher was used with all bolts.
    • Keith M.
      Infrequent User
      • April 30, 2001
      • 27
      thank you for your help
      • Wayne M.
        • March 1, 1980
        • 6414
        Here's the bolt heads on the rear caliper.
        c
        • Jim S.
          • March 13, 2013
          • 360
          Wayne, I think Keith was asking about the mounting bolts. You don't have those pictured ;-)
          • Wayne M.
            • March 1, 1980
            • 6414
            .....A thick split lockwasher was used with all bolts.
            Joe, Keith --- I don't recall ever seeing a split lockwasher, fronts or rears. Also the exploded view in the Shop manuals and the P&A parts books show no washer.
            • Wayne M.
              • March 1, 1980
              • 6414
              Sorry -- thought the subject was caliper half bolts. Too early in the morning out here .
              Just checked and I agree with the 6 radial lines.
                • 43273
                Wayne------
                The caliper half bolts used for 1965-E67 were PLACE bolts as you have pictured. This type of bolt has an inherent locking capability; that's the only reason for using place bolts. Strangely, the L67-82 bolts were just conventional hex head bolts and no lock washer was used. So, I guess for 1965-E67 1st design calipers GM thought that thread locking was important (place bolts are expensive; in fact, far more expensive than a plain bolt with a lock washer). However, for 2nd design L67-82, they apparently reconsidered and felt that NO thread locking was needed.
                • Rich P.
                  • January 12, 2009
                  • 1361
                  Original head markings include, 0, TR, M, WB and []. Rear caliper bolts could be threaded all the way or sometimes the spindle flange to 1/2 shaft flange bolts were used which have a 3/8" or so shoulder. Front bolts are 1-1/4" and rears are 1"
                  • Keith M.
                    Infrequent User
                    • April 30, 2001
                    • 27
                    thanks ...how about head marking with a 5 in the middle and 3 lines radiating out and SSC between lines...thx
                    • Rich P.
                      • January 12, 2009
                      • 1361
                      5 w/ssc is replacement. Not assembly line installed.
                        • 6956
                        Keith, just curious what year is your corvette? I had some of those bolt head markings on my 63 and thought these bolts looked like they had been on there many years due to the rust. they where I believe attaching my front bumpers if I remember correctly.
