Radiator Overflow Hose size - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    What is the correct length, the I.D and O.D. of the smooth wall radiator overflow hose on a 70 L46?
    Bill
    • 6950
    Re: Radiator Overflow Hose size
    Bill, not sure if it matters but A/C cars and non A/C may matter in length.
    • Mark E.
      • April 1, 1993
      • 4602
      Bill
      "radiator overflow hose"... I don't know off hand either, but which hose are you asking about? The small diameter hose that goes from the radiator to the expansion tank? Or the overflow discharge hose attached to the neck of the expansion tank?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Bill L.
        • February 1, 2004
        • 1403
        Overflow discharge hose. L46 did not have expansion tank.
        Thanks, Bill
        • Mark E.
          • April 1, 1993
          • 4602
          It looks like Doc Rebuild sells them:
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Bill L.
            • February 1, 2004
            • 1403
            http://www.docrebuild.com/dr-r-web/RAD-HOSE2.pdf
            My understanding is the hose should not have ribs. I have the Doc Rebuild hose.
              • 11669
              My 1972 has ribs on it, and it sure doesn't look like it has ever been off the car.
              Same with another 72 that I care for.
              Yes, I know that it's a different year. Just giving two data points for the same hose.
              • Bill L.
                • February 1, 2004
                • 1403
                Well I guess for now I will keep the ribbed Doc Rebuild hose.
                Seems there may be some conflicting info if I have read other threads correctly.
                Thank you
                • Mark E.
                  • April 1, 1993
                  • 4602
                  My '70 454 AC car has an overflow hose with ribs. I don't know if it's original but it's stiff and brittle and has been installed since at least January 1990.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Mike E.
                    • February 28, 1975
                    • 5141
                    Bill,
                    My unmolested 70 L46 built in March has a ribbed hose. It still has the clip on the radiator and the black plastic loop that pushes into the inner fender, so I'm really convinced it is original. It is thin wall hose, ribbed, ID 3/8, OD 1/2". Best guess on length is about 24".radiator overflow hose and clips (2).jpg
                    • Bill L.
                      • February 1, 2004
                      • 1403
                      Originally posted by Mike Ernst (211)
                      Bill,
                      My unmolested 70 L46 built in March has a ribbed hose. It still has the clip on the radiator and the black plastic loop that pushes into the inner fender, so I'm really convinced it is original. It is thin wall hose, ribbed, ID 3/8, OD 1/2". Best guess on length is about 24".[ATTACH=CONFIG]63207[/ATTACH]
                      I will keep what I have then. Thank you Mike.
                      Any chance of getting a picture of the clip and the Black Plastic Loop?
                      Kind Regards,
                      Bill
                      • Mike E.
                        • February 28, 1975
                        • 5141
                        Bill,
                        I injured the clip but I think the picture will help. The thin-wall hose is long enough to extend down between the gap in the radiator support and the frame, so that if it has to dump fluid, it does so on the ground, not on any car parts. I also included pic of radiator tag.
                        Mike
                        radiator overflow hose and clips (3).jpgradiator overflow hose and clips (4).jpgradiator overflow hose and clips (5).jpgradiator overflow hose and clips (1).jpg
                        • Bill L.
                          • February 1, 2004
                          • 1403
                          Bill,
                          Mike
                          [ATTACH=CONFIG]63209[/ATTACH][ATTACH=CONFIG]63210[/ATTACH][ATTACH=CONFIG]63211[/ATTACH][ATTACH=CONFIG]63212[/ATTACH]
                          Thank you Mike.
                          Just what i needed.
                          Bill
