1963 Coupe Barn Find And New to NCRS - NCRS Discussion Boards
  • Donald H.
    Infrequent User
    • August 3, 2015
    • 11
    I just rejoined NCRS after a lapse of decades.
    I purchased a '63 coupe a few weeks ago. It was last licensed 30 years ago, and parked in a barn 28 years ago. I have known the car since a friend bought it in 1976, in Grimsby, Ontario, Canada. If my memory serves me correctly, the car had been imported into Canada a short time before.
    Tragically, my friend died in a SCUBA diving accident 7 years ago, and I purchased the car from his widow, who is also a dear friend.
    The car is Daytona blue with dark blue interior. Engine is matching number 340 HP. It has a has a "67 big block hood and "67 lower front fenders. Scallops in the 'B" pillar are filled, probably with bondo. No front bumpers, and has a Hurst shifter. In the lower front corner of the driver's side rear window is a "Sheriff's Association of Texas" decal. Just wondering if anyone recognizes the car. I realize these mods were quite common back in the day.
    My intent is to repair, and to some extent restore the car and drive it. At a minimum "do no harm".
    Coolant was drained, battery was removed, and it looks like the oil was changed before the car was parked. Fortunately the barn floor is crushed limestone, which made for a dry environment in a high humidity area.
    I pulled the plugs and squirted Marvel Mystery Oil in the cylinders a couple wees ago, but haven't tried turning the engine.
    Interior was well worn when the car was parked, Seats and carpeting need replacement. There were chipmunk living inside, so there is a strong urine odor. Any suggestions for eliminating the odor?
    I expect to replace the master cylinder and wheel cylinders as part of a brake overhaul. I assume that they are original. I will save the master cylinder "for the next guy". Is there any value in saving the wheel cylinders?
    Yes it really was in a barn, although it was never lost.
    Any help is much appreciated. Thanks
  • Keith B.
    • September 15, 2014
    • 1604
    Re: 1963 Coupe Barn Find And New to NCRS
    If you remove the carpet I'm sure the smell will go away. Unless it got into the seats. Then new foam and covers will help. Sounds like a neat car.
    • Brian D.
      • April 30, 1999
      • 425
      Congratulations on your new (to you) iconic Corvette!
      Just curious as to its trim tag build date. I was born Oct 9, 1962 and I'm always seeking a B2 code car - not to buy, but just for the fun of knowing that there's one about my own age.
      B.D.
      • Timothy B.
        • April 30, 1983
        • 5202
        Donald,
        Don't throw anything away, wheel cylinders etc. Look the carpet over good because you may be able to remove it and clean before making decision on replacement. Enjoy your new find, take things one at a time and stay tuned here on the TDB.
        • Mike T.
          • January 1, 1992
          • 569
          Don - Welcome back. Post up some pics of your 63, we'd like to see them.
          Mike T. - Prescott AZ.
          • Mark E.
            • April 1, 1993
            • 4607
            Donald,
            Cool car! We're all glad it has a good home.
            You might ask NCRS if you can use your original member number to honor your experienced background. They resurrected mine when I rejoined. And as we all know, it's nice to have original numbers...
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Tom D.
              • September 30, 1981
              • 2145
              Welcome and have a good time working on your car!
              If it is an early (or late) '63, learn the many things that changed during the model year.
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Donald H.
                Infrequent User
                • August 3, 2015
                • 11
                Thanks all, for the advice. Build date code is G3, which I belive is 3/15/1963,
                The carpet is too far gone to salvage - dry rotted and torn. This was a high mileage car even in 1976.
                I tried to post pictures, but the file are too big. My daughter is a college photography major, so I will get her to help me.
                The Woodward Cruise (unofficially) starts tonight, and runs through Saturday 8/15. I always take the week off from work, so I can work on the cars during the day, and enjoy the smells of burning rubber, race gas, and av gas during the evening.
                I may be posting questions on issues that I run across.
                Thanks guys. I am enjoying the ride and I haven't even driven it yet.
                • Donald H.
                  Infrequent User
                  • August 3, 2015
                  • 11
                  Donald,
                  Thanks Mark. Great suggestion. I am back to being #3523. Yes, I know. I'm old.
                    • 6956
                    Don, saw your post on the carpet, if all possible save the heel and toe pads for 63 they are not reproduced. you can have someone like A. K. sew them into your replacement carpet.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      You have a great car.....I've had mine 2-1/2 years now and learn something new about it nearly daily....
                      There were rolling production changes almost monthly; VIN number ranges are the best way to identify the changes...
                      Be careful with repro parts -- some are total Chinesium or bad, bad attempts....headliners are a case in point.
                      If the original is OK or can be saved then DO IT !!! If not then Al Knoch has the only repro that comes even close !
                      • Jeff M.
                        • July 27, 2009
                        • 72
                        Congrats on the 63. As you start going through it you will learn a lot. 63's are very interesting with all of the changes throughout production. Make sure and buy the most recent judging manual if you havnt already. Good luck with it Jeff
                        • Michael B.
                          • February 1, 1980
                          • 61
                          Hey Donald,
                          Congrats on your new project. Just finished a '63 roadster restoration. Its VIN 113XX, which was built in the fourth week of March. I live in the Detroit area, so if you ever have any questions or just want to discuss the finer or less fine points of '63's, don't be shy.
                          Mike
                          • Tom D.
                            • 2145
                            I hauled the above mentioned '63 (Mike Bailey's, body only) from my favorite paint shop back to his garage. I think Mike will agree that I am a good body transporter, if it comes to that. The painter is reasonable also, if you intend to go with clear coat. I am coaching him to do more "original style" mid-year painting, but he prefers to do better than St. Louis did.
                            Michigan Chapter
                            Tom Dingman
                            • Tom S.
                              • August 31, 1994
                              • 137
                              Hey Don,
                              check the C-2 Registry under Vin# 10803 sounds like the same car. Some of those details just can't be on another car. Often wondered what happened to it. Boy do have I some stories about this one and some pictures too besides the ones on the Registry.
