1971 fan shroud - NCRS Discussion Boards
1971 fan shroud
  • Harmon C.
    • August 31, 1994
    • 3228
    1971 fan shroud
    Is the number in raised numbers on a 71 Lt-1 fan shroud? I would like the number as it is not in the TI&JG.
    Lyle
    • 43202
    Re: 1971 fan shroud
    Lyle-------
    All that I have seen were raised. However, I can't say that every one ever made was like this. The number is 3956109.
    • Paul Y.
      • September 30, 1982
      • 570
      Re: 1971 fan shroud
      Joe, Lyle, is the AC shroud the same number or same shroud if no number?
      It's a good life!
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: 1971 fan shroud
        Is the complete number in raised form on the shroud?
        Lyle
          • 43202
          Re: 1971 fan shroud
          Paul-------
          If you're talking strictly about LT-1's (except ZR-1), the AC and non-AC used the same 3956109 fan shroud. The AC-equipped examples MAY have used a fan shroud EXTENSION. The 3956109 shroud was also used on all 1969-72 small blocks with copper/brass radiator.
            • 43202
            Re: 1971 fan shroud
            Lyle-------
            On all examples I've seen, the complete number is present and raised characters.
            • Leif A.
              • August 31, 1997
              • 3617
              Re: 1971 fan shroud
              Don't believe A/C was available on the LT1 in 1971...not until 1972.
              Leif
              • Paul O.
                • August 31, 1990
                • 1716
                Re: 1971 fan shroud
                A photo from a 1969.
