Re: 1964 c2 ignition issue
As soon as I read your post I was thinking rotor contacting the contacts in the cap as Frank shows in post #12. I have had this happen before also on 2 different cars. Running fine, a couple backfires and then nothing. Removing the cap showed the rotor contact at about a 45* angle just like the picture. Excessive end play in the distributor shaft was the problem. New shaft bushings and proper shimming and it was good to go again.
The 1956 did this at high rpm and I was sure I'd just lunched the engine. Boy was I relieved.
Tom
Tom
