1964 c2 ignition issue - NCRS Discussion Boards
  • Tom B.
    • March 1, 1978
    • 720
    Re: 1964 c2 ignition issue
    As soon as I read your post I was thinking rotor contacting the contacts in the cap as Frank shows in post #12. I have had this happen before also on 2 different cars. Running fine, a couple backfires and then nothing. Removing the cap showed the rotor contact at about a 45* angle just like the picture. Excessive end play in the distributor shaft was the problem. New shaft bushings and proper shimming and it was good to go again.
    The 1956 did this at high rpm and I was sure I'd just lunched the engine. Boy was I relieved.
    Tom
    • Michael W.
      • April 1, 1997
      • 4290
      Originally posted by Philip Arena (48654)
      The answer to your question is yes. I have had TWO of these breakerless conversions fail. The symptoms are consistent with your experience. The net result is no spark coming out of distributor. I have returned to points without issue.
      But there would also be no spark directly from the coil either, which is not the case with the OP.
      Originally posted by Jef Steingrebe (52553)
      that's kind of what I'm getting. Ill try changing the cap and rotor if that doesn't work I guess the next step is pulling the fan water pump and timing change cover right?
      Nooooooooooooooooo............
      You're a long way from that kind of drastic action. A 'jumped' timing chain will not affect the availability of the ignition to produce a spark.
      • Dan B.
        • July 13, 2011
        • 545
        I'd swap back in the conventional points and related parts to your distributor which will then allow you to work backwards with a conventional trouble light to confirm where the problem is. I'd bet after reading all this that your Breakerless gizmo gave out. As others have said, for the amount of miles most of us drive our cars, maintenance on the conventional point system is really quite minimal and after 40+ years I have yet to experience a single failure. How much more reliable can you get?
        • George J.
          • March 1, 1999
          • 775
          I had a coil go bad on a road trip one time. Replacing it still didn't make the car run correctly all the time. It needed a condenser, as well. Change out the easy ignition parts first.
          George
          • William F.
            • June 9, 2009
            • 1357
            Which brand of breakerless ignitions went out on you? Pertronix or "Breakerless" like sold by M&H, I believe?
            • Frank D.
              • December 27, 2007
              • 2703
              Who said his points conversion "went out" ?
              It was just posed as on possible cause of his problem, along with ignition coil, distributor cap, etc..
              • William F.
                • June 9, 2009
                • 1357
                Frank,
                PHILIP clearly said HE had 2 of the breakerless conversions go out.
                • Michael W.
                  • April 1, 1997
                  • 4290
                  spark from the coil into the distributor yes, not coming out of the distributor.
                  Somebody will have to explain how the above is possible if the pertronics widget or coil is bad.
                  • Frank D.
                    • December 27, 2007
                    • 2703
                    #24
                    Proper question....the first thing people seem to want to do is damn an electronic points conversion as the obvious culprit.
                    Run them for decades never a failure; the failures I've seen in others' cars have been bad installs or abuse...
