1973 SB Air Conditioning Belt - Need Some Help - NCRS Discussion Boards
  • John S.
    • June 15, 2015
    • 506
    Re: 1973 SB Air Conditioning Belt - Need Some Help
    Ralph, thanks for the info on the 58 1/2" belt, I'll see if I can get some info on that P/N.
    Ed, no deep drive pulley on my AC compressor, form the photos mine looks identical to yours.
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • John S.
      • June 15, 2015
      • 506
      So after a bit of shipping back and forth along with a weeks vacation on my part I'm happy to report that Quanta got me a 58" A/C belt that fits my '73 SB - extremely tight fit, but it fits.
      They were able to measure the belt I returned and determined it was under spec. The new belt they sent was apparently only a 1/4" longer, but it was just enough to get everything together.
      Tension on the belt is just about perfect but I only have about 1/8" clearance between the A/C compressor and the valve cover. Hopefully things will loosen up as I run it and I can get some additional clearance.
      Hat's off to Quanta for working with me and getting the issue resolved !!
      • Jimmy P.
        • June 24, 2014
        • 1696
        #18
        Hi John,
        Glad to hear things finally worked out. As we've talked about before, it's these little things that drive you crazy
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
