68 427 fan clutch mounting - NCRS Discussion Boards
  • Douglas L.
    • May 8, 2015
    • 181
    A little confused here... How was the fan clutch mounted to the water pump and fan mounted to the fan clutch on a 68 with the Eaton fan clutch? Studs mount the the clutch to the water pump and bolts mount the fan to the clutch?, vice versa?, all studs?, all bolts?
    Thanks, Doug
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 68 427 fan clutch mounting
    bolts used for clutch to pump. Studs with nuts used for fan to clutch
      • 43288
      Thanks, Doug
      Doug------
      Studs for attachment of clutch to waterpump hub began with the 1969 model year.
      • Douglas L.
        • May 8, 2015
        • 181
        Thanks Joe. I guess I should have looked in TIM&JG first.
          • 43288
          Steve------
          Not all 1968 fan clutches used studs for attachment of the fan to the clutch. The GM #3937771 used bolts.
          • Douglas L.
            • May 8, 2015
            • 181
            Steve------
            So did the GM #3916141, use studs in 68?
              • 43288
              Doug-----
              For the fan blade to clutch, definitely yes.
