1970 rocker molding front tab screw - NCRS Discussion Boards
  • Kenneth B.
    • August 31, 1984
    • 2091
    My 2 1970 Corvettes have the original rocker moldings & neither one has & doesn't look like there was ever a screw hole where one was. The LT-1 coupe has original paint & the 454 conv. had one repaint by me. I wonder if it was not needed or used at assembly. Do all later years have the tab & screw or is it cut off like the OTC ones?
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 1970 rocker molding front tab screw
    The ones I have worked on and owned have the screw.
    • Kenneth B.
      • August 31, 1984
      • 2091
      OK thanks Russ. I know the JG calls for them. I was just wandering if the line worker sometimes left them out. Again did the later years have the tab?
      • Bill C.
        • July 15, 2007
        • 904
        Ken
        was your car an early build?
        maybe they were skipped and did not start till later 70....
        my 72 did have the screw and j nut
        I was first person to take it apart.
        The tab was on the rocker moldings till 75 or 76 ( I think)
        bill
        • Mike E.
          • February 28, 1975
          • 5141
          My March 2-owner 70 has original screws and j-nuts. FWIW
          • Dave S.
            • August 31, 1992
            • 2926
            Any 70-72 original car I have seen has the J nut and screw. Could be a cross recess or an indented hex nut with integral washer. 70's seemed to have cross recess and later 70's and newer seem to be predominately hex head.
            • Don L.
              • August 31, 2005
              • 1005
              I'm away from my JG, but think it says the hex head screw first showed up in 1972. Perhaps someone will look and ring in. My '72 has them...
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Dave S.
                • August 31, 1992
                • 2926
                Don,
                i'm sure that will be corrected in the new JG. My 1971 #16798 and #21467 both have the hex heads and many other 71's have been seen with them as well.
                • Don L.
                  • August 31, 2005
                  • 1005
                  Don,
                  Thanks Dave. I could be remembering wrong too. JG may already have '71s with them. I just can't tell because I'm away. BTW, my '72 is a very early car, featuring numerous components and features that were part of the commonly known '72 features, showing that coordinated obsolescence wasn't a high priority then, a it is now.
                  Don Lowe
                  NCRS #44382
                  Carolinas Chapter
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    73 was the last year for the tabs on the rocker moldings.73's had hex screws.
                    Lyle
