C2 head light ball & cup greese - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    What is the best grease to put on the head light balls and cups
  • Paul J.
    • September 9, 2008
    • 2091
    Re: C2 head light ball & cup greese
    Bill,
    I use plain ole white lithium grease, but that is what I was taught was correct for friction surfaces like striker plates and door hinges. This is probably not OEM, if there was any grease used at all. I've often wondered if silicone grease is a better alternative, since it is specifically called for in plumbing applications where water is present. Perhaps someone more knowledgeable will chime in.
    Paul
    • Jim S.
      • March 1, 1986
      • 1408
      Bill,
      If memory serves , the felt seal that goes next to the bearing should be oiled , but the ball and cup were not , nor were they supposed to be , greased.
      That being said I think I applied a very light coat of Black Chassis Grease to mine , just cause !
      Jim
      • Russ S.
        • April 30, 1982
        • 2162
        I don't recall whether I used white grease or never seize.
        • Wayne W.
          • April 30, 1982
          • 3605
          Use the nylon balls and lub is not really necessary.
          • Joe R.
            • July 31, 1976
            • 4551
            Would recommend using any synthetic based bearing grease that has the viscosity to stay in the bearings and the metal balls/cups. I would never be caught dead with nylon balls on an NCRS restoration!!!!! LOL
            JR
            • Wayne W.
              • April 30, 1982
              • 3605
              Wouldn't have the balls to do it JR.
                • 15706
                White lithium grease tends to dry out fast. I recommend a synthetic like Mobil 1 grease.
                • Russ S.
                  • April 30, 1982
                  • 2162
                  DITTO on the nylon balls Joe Ray!!!!! DITTO!!!!
                  JR
