Tach cable - NCRS Discussion Boards
Tach cable
  • Paul S.
    • October 29, 2014
    • 16
    Tach cable
    When putting in a Tach cable or Speedometer cable, what end do you put the brass button on? Gauge side, or distributor/ transmission side.
    • 43202
    Re: Tach cable
    Paul------
    I don't know of any brass button associated with either a speedometer or tachometer cable. What brass button are you referring to?
    • Don L.
      • August 31, 2005
      • 1005
      Re: Tach cable
      Hi Paul. I too am a bit confused with your reference to "brass button". The only brass button that comes to my mind is a service replacement button that goes into the distributor to maintain positioning for the tach drive gear. I've attached a pic of the button I'm thinking about below:
      Might this be what you have in mind?
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Paul S.
        • October 29, 2014
        • 16
        Re: Tach cable
        Hi Don, That's not the part. On one end of the cable, about 1" in, there is a brass or nylon collar that when you put it into the shield, it bottoms out. Which one is correct? 061415_2127.jpg061415_2128.jpg
          • 43202
          Re: Tach cable
          Hi Don, That's not the part. On one end of the cable, about 1" in, there is a brass or nylon collar that when you put it into the shield, it bottoms out. Which one is correct? [ATTACH=CONFIG]61420[/ATTACH][ATTACH=CONFIG]61421[/ATTACH]
          Paul-------
          For most C3's, the instrument (i.e. speedometer and tachometer) end of the cable has a "snap-on" connector and the drive (i.e. transmission or distributor) end uses the knurled, screw-on connector. So, it's pretty easy to determine which end goes where.
          • Paul S.
            • October 29, 2014
            • 16
            Re: Tach cable
            Sorry about the confusion. I know what side the connectors go on, I am wondering where the Black nylon stop goes. I put it in the cable in the shield both ways. Which one is the correct way?
              • 43202
              Re: Tach cable
              Paul------
              The stop, as you call it, goes on the instrument end.
              • Paul S.
                • October 29, 2014
                • 16
                Re: Tach cable
                Thanks for all your help Joe.
