I need the help of a few of you engine experts out there.  I recently had our 1966 325/350 L79 rebuilt.  Runs great, but I noticed it seems to drink a little oil during break in.  No leaks..., but I noticed a little smoke out of the passenger's side exhaust.  Drove it a little more and now notice smoke out of both sides especially when engine gets hot.
The oil pressure on the gauge reads very high at start up then lowers at idol after driven a while. Gauge still reads high, but I have not checked to see if the gauge is calibrated yet. I intend to.
I just purchased some other parts from Paragon and was reading their catalog and came across their oil pumps. I noticed they say, "High Pressure oil pump, all 327. Use with caution as pressure could cause seals to blow." This was on part 10367
I know a new high pressure oil pump was in my rebuild.
Does anyone have a similar experience or knowledge in this area?
I am going to check the true oil pressure with another gauge, then decide if I need to change the oil pump to a new standard pressure pump. Also plan to change the valve seals.
Any insight is greatly appreciated.
Thank you
Jeff
Thank you
Jeff
