Best sealer for Manifold hose nipples - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    On a prior thread about Rusted or seized Hose fittings in Aluminum Intakes , it was pointed out that thread damage may occur from removing them . This then could cause Anti Freeze leakage .
    Without knowing whether this is or will be the case , and perhaps regardless, what is the best preventative to use ?
    I think I used Teflon Tape on the nipple threads , but was considering using Permatex Ultra Copper . Are either a good or bad idea , possible point deduction aside ?
    Jim
    • 43273
    Re: Best sealer for Manifold hose nipples
    Jim
    Jim------
    I think Teflon tape works very well. I sometimes use it. However, I think a better solution is Permatex Pipe Thread Sealer with Teflon. That's what I use most often. It's available under a GM part number but you can also get it in most auto parts stores.
    • Larry M.
      • January 1, 1992
      • 2701
      Jim------
      Joe offers good advice. My personal choice for a sealer for this application is Loctite/Permatex High Temperature Thread Sealant with Teflon. Part # 59214/31/35 depending on size tube. Also available under NAPA #765-1155. Good to 400F. White paste.
      I Have used both in the chemical plants and on my own cars. Good stuff.
      Larry
      • Gary C.
        Administrator
        • October 1, 1982
        • 17929
        Jim,
        The aircraft guys all use a product commonly called Fuel Save. The newer version of that product is EzTurn Lube. Available at aircraft supply stores. http://www.aircraftspruce.com/catalo...ezturnlube.php
        I use it on all brake and fuel lines and other fittings.
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Jim S.
          • March 1, 1986
          • 1408
          Thank You Gentleman !
          • John D.
            • December 1, 1979
            • 5507
            On the FI intakes/baseplates I use Loctite 545 hydraulic sealant on the fittings. Never had a problem with leaks.
              • 15706
              Pipe joint compound that you can buy at any hardware store. It's suitable for sealing water and steam pipes and provides anti-seize properties. Also, I am not aware that NPT fittings have a recommended torque spec. They should only be tightened enough to be leak free. I think many over-torque them. They should just be snug - maybe 10 lb-ft.
