Manual shutoff valve - NCRS Discussion Boards
  • Harry L.
    • December 22, 2008
    • 370
    Will one 5/8" heater hose valve on the hose from the manifold keep all the hot water out of the heater core, or should I also put a 3/4" shut off valve on the hose from the waterpump to the heater core? I prefer using the Manuel shutoff valves for my BB a/c system. Dutch
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Manual shutoff valve
    Only one valve is required. Either hose can be used, whichever is most convenient.
      • 15706
      One word of caution. Lack of coolant circulation can cause localized corrosion (in the heater core in this case), so it's a good idea if the valve has a "pinhole" leak to allow very slight circulation when the engine is running or open it for a couple of minutes once every month or two.
      • Larry M.
        • January 1, 1992
        • 2700
