How well does the reproduction firewall insulation fit on a C2 - NCRS Discussion Boards
  • Chester C.
    • May 29, 2013
    • 154
    Has anybody installed the reproduction firewall insulation for a 63. How well did it fit. Did it fit all the curves and dips as it should. What vendor did you buy from, thanks.
  • Russ S.
    • April 30, 1982
    • 2163
    Re: How well does the reproduction firewall insulation fit on a C2
    I have put the f/wall insulation in a couple of 65-66s and one of the holes in the driver side piece that a retaining plug goes thru never lines up with the hole in the center piece of insulation. These would have come from either Corvette Central or Long Island.
    • Page C.
      • February 1, 1979
      • 802
      Some of the jute material I seen is gray in color instead of the original tan.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11334
        Page, A set I installed a few years ago on a '67 was that. I just couldn't do it.
        I decided to make it look more original by splicing in pieces from the original tan jute backing. Tedious, but the gray just didn't look right and it looked better when I was done.
        BTW, the fit wasn't that great around the firewall pedal brace. I had to trim it a bit.
        Rich
        Before
        During
        P3210026.jpgP3210027.jpgP3210028.jpgP3210029.jpgP3210030.jpgP3210031.jpgP3210032.jpgP3210033.jpgP3210034.jpgP3210035.jpgP3210036.jpgP3210037.jpgP3210038.jpg
        After
        • Chester C.
          • May 29, 2013
          • 154
          Sure has some deep creases. What is the board made of. ABS plastic or some kind of vinyl.
          • Russ S.
            • April 30, 1982
            • 2163
            It's more like pressed cardboard.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              Yes it's a thick cardboard with a tar-paper like texture. It must be made in some type of 2-part mold, probably heated. Very expensive so it must be a unique process.
