C3 Fresh air vent - NCRS Discussion Boards
C3 Fresh air vent
  • Jim S.
    • March 1, 1986
    • 1408
    C3 Fresh air vent
    Hey Guys
    Which side is up or down , or which way are the two center pins supposed to face ,forward toward the firewall or rearward toward the door , on the left side (driver's) fresh Air vent . C-60 car if it matters .
    Jim
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 Fresh air vent
    No replys yet, however just information to pass on,my 1970 coupe with factory air does not have a fresh air vent on the drivers side, it came from the factory sealed closed.
    • Jim S.
      • March 1, 1986
      • 1408
      Hi Jim,
      Thanks for the follow up.
      My title is mislabeled. It should read C2, as I am inquiring about a 66. I can no more figure out how to change the title than I can figure out which side is which !
      Jim
      • Roger G.
        • October 11, 2012
        • 268
        Hello Jim,
        I cant answer for a c2, but on my non AC 69, the part where the cable attaches is closer to the firewall, this means one will be right side up and one will be upside down, in other words the spring will be on top one side and on the bottom on the other side
        • Jim S.
          • March 1, 1986
          • 1408
          Roger,
          Thanks .
          On A/C cars the passenger vent is totally different. So I only have one that looks like the picture , and as you pointed out it fits either way .I will try it with the cable attachment closet to the firewall and hope for the best .
          Jim
          • Roger G.
            • October 11, 2012
            • 268
            Jim, no prob, stated another way.....the cable has to pull across the pivot for the door to open
            Roger
