1966 Front License Plate Bracket - NCRS Discussion Boards
  • Edmund C.
    • April 14, 2015
    • 232
    Guys: What do I need to put a license plate bracket on my 1966 Corvette? Nothing appears to be there. I saw the kits on Ecklers, yet, how is it actually attached to the vehicle? Does it go between the bumper brackets or do I need to drill into the body (Heaven forbid)? Help a Corvette guy out.
  • Jim D.
    • 2885
    Re: 1966 Front License Plate Bracket
    A chrome plated bar bolts to the brackets that are welded to the inside of the bumpers. The black steel license plate bracket bolts to the bar. Nothing touches the body.
    • David L.
      • July 31, 1980
      • 3310
      You can look in a 1966 Corvette Assembly Manual, UPC 14, sheet A2, or you can look at the drawing below which is basically the same except for some part numbers. There should be two small holes in the chrome bar (GM # 3797439) between the front left and right bumpers.
      Dave
      • Donald H.
        • November 2, 2009
        • 2588
        Look at UPC 14 - A2 in your AIM and you will see the parts you need. The bar to mount the license plate bracket is available as a reproduction.
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
        • Don H.
          Moderator
          • June 16, 2009
          • 2280
          Edmund,
          see if these photos help you out.
          Joe,
          sure, but you know how rare those are, and I think it was just 67 that offset the bracket for A/C.
            • 43273
            Originally posted by Don Hooper (50543)
            Edmund,
            [ATTACH=CONFIG]60621[/ATTACH] [ATTACH=CONFIG]60622[/ATTACH]
            Don and Edmund-------
            Except for cars with C-60.
            • Edmund C.
              • April 14, 2015
              • 232
              Wow, you guys are truly amazing. Many thanks! I assume the cross bar is also available from Ecklers, etc.?
              • Edmund C.
                • April 14, 2015
                • 232
                Just to be clear, I need the bumper cross bracket; the license plate bracket; and a specific bolt kit - is that correct? Can I get everything from Ecklers? Thanks guys and sorry for the Sophmoric questions (but, this is pretty specific hobby I'm gathering from the detailed responses on various Forum topics). I'm starting to think I'm in for a rude awakening at my first NCRS Show. It'll be fun, albeit tough I imagine.
                • Joe R.
                  • July 31, 1976
                  • 4552
                  Edmund,
                  Yes, Ecklers will have everything you need. Also, every other Corvette warehouse can supply you with the specific parts. The front License Bracket was once supplied by GM under part number 3878898.
                  JR
                  • Keith B.
                    • September 15, 2014
                    • 1600
                    I would order everything from Paragon Corvette or Long Island Corvette before anyone else. They specialize in parts not lifestyle clothing
                    • Harry S.
                      • July 31, 2002
                      • 5344
                      Yes, and Paragon will give you a 10% discount when you tell them you are an NCRS member. They will add it to your profile so when you order online it becomes automatic.
                      • Edmund C.
                        • April 14, 2015
                        • 232
                        Gents: Many thanks. I'm calling Paragon right now.
                        • Gary B.
                          • February 1, 1997
                          • 7066
                          Keith,
                          Do you know if the repro bracket sold by Paragon or LIC has the sp (or upside down it's a ds) stamping on it? That is something I've seen judges look for.
                          Gary
                          • Keith B.
                            • 1600
                            No I do not. that would be something you would have to call Paragon about. I would not call LIC they get a little funny about asking questions like that. but I am sure there are plenty of used originals out there
                              • 43273
                              Edmund,
                              Joe,
                              Don-------
                              1966 and 1967.
