1954 engine not original - NCRS Discussion Boards
  • Donald M.
    • March 27, 2015
    • 98
    My '54 Vette has a proper Blue Flame Corvette engine that is in and of itself an original complete engine. The problem is that it is not the engine that came with the car. How will this alone affect the judging of my car?
    Don
  • Edward L.
    • 278
    Re: 1954 engine not original
    If it is an original '54 engine that has never been decked, the only thing that could affect the judging is the engine build date. If the date is within 6 months of the car's completion there should be no deduction. If greater than 6 months, or if after the car's build date, you would lose 175 points. (approximately 4% of total score.
    1956 and later cars where there were engine options, other factors that could affect scoring would come into play.
    • Donald M.
      • March 27, 2015
      • 98
      Thank you, Edward. That's a definitive answer. Unfortunately, this is enough to deter me from proceeding down the NCRS path. On the other hand, I'm going to have one heck of a fine driver.
      Don
      • Chuck G.
        • May 31, 1982
        • 2034
        Don
        Don't be discouraged.
        You can calculate the build date of your 54. From that info, you can "guess" what the casting date of the motor could be.
        If it falls within the 6 month judging parameter, you'll be fine.
        You didn't mention this, but all 54 Corvette motors have a "911" casting number in addition to the casting date and the engine serial number and suffix stamped on the pad.
          • 3416
          Hi Donald,
          This really shouldn't 'close the door' on the NCRS path for you and this car.
          If the rest of the car is very nice and typical of production it could still score well.
          In addition since you mention driving it, you could plan a pretty long drive to a meet and gain back some of those 'lost' points with 'driven' points.
          Please reconsider!
          • Donald M.
            • March 27, 2015
            • 98
            Chuck, it is a 911 block, and it was definitely produced after my car's production date. So I lose the points.
            Don
            • Donald M.
              • March 27, 2015
              • 98
              Alan,
              At the risk of bringing down on myself the wrath of the NCRS faithful (I say this in the spirit of good-natured ribbing and do not mean to denigrate the wonderful and valuable work NCRS does.) I have made other modifications. Specifically, HEI ignition (still 6v), rack & pinion steering, wire wheels, and radial tires. In my favor, I have (at great expense) restored the original gauges, clock, radio, wiper motor/washer, turn signals, courtesy lights, dash lights, and other minor electrical issues. None of the modifications I have made could not be restored as I have retained the stock ignition system, original wheels and wheel covers, tires, and all suspension parts. Oh, I also installed an after-market 15" steering wheel that I have had covered to resemble the stock wheel. I did this rather than destroy the rather nice stock, original steering wheel, which, of course, I have retained.
              The car has a beautiful, flawless paint job, top drawer interior, and the mechanicals are freshly rebuilt. The body does not have a single indication of accident damage, and the frame is totally rust free and flawless. It is a wonderful car.
              Don
              • Chris S.
                • January 1, 2000
                • 1068
                Don
                as above the block should be a "911" block.
                The suffix should be a 54 YG
                The date code of the block is cast and sits in behind the starter.
                As above if the date is close to the build date - should be - should be with in 6 months or so
                The block was not VIN specific
                  • 3416
                  Hi Don,
                  As long as you restored/built the car the way YOU wanted, all is good.
                  Check out the Sportsman Award. It might be perfect for your car.
                  As you can tell I want you AND your 54 to begin attending events!!!
                  • Chuck G.
                    • May 31, 1982
                    • 2034
                    Don
                    You can lose ~270 points, and still get a Top Flight Award. With the 10 point bonus for the decal, fire extinguisher, and battery cut-off, that brings it up to ~280.........
                    4510-280 = 4230. 4230 divided by 4500 = 94%.
                    Chuck
                    94% is the lowest TF score. You could do it IF THAT'S WHAT YOU WANT TO DO.
                    • Donald M.
                      • March 27, 2015
                      • 98
                      Okay. I'm a player. Anybody know where I can pick up a dual pot intake system cheap?
                      Don
                      • Donald M.
                        • March 27, 2015
                        • 98
                        BTW Chris, I absolutely approve of you sig file.
                        Don
                        • Chris S.
                          • January 1, 2000
                          • 1068
                          Don
                          I have a couple twin pots and lids - I can offer to you
                          To find a complete system is not a cheap affair - sorry
                          • Chris S.
                            • January 1, 2000
                            • 1068
                            Don
                            Thanks !!! I need to update it....... 1953 #201 body work completed and in primer and 1953 Waldorf Motorama replica - body work started and 1959 270hp 2x4 car - body work started............ Love the C1's
                            • Guy M.
                              • November 1, 1993
                              • 500
                              Don, My engine isnt original either. Mine is resurrected now after a 22 year restoration. Im strugling with the same issue. I live 15 miles away from the hotel of this years convention and was thinking about driving mine there to get some opinions to see if its worthy. Canvas top is going on June 22 and short of the radio its complete (finally). Stay the course.
