1956 Early Exhaust System - NCRS Discussion Boards
  • Sheldon S.
    • February 28, 1999
    • 474
    I have a early 56 that has the 2 hole exhaust manifolds. I am looking for a exhaust system for it, I have checked both Gardner and Allens but neither one has the 2 hole system. Any suggestions on what to do.
    Sheldon
  • Willard M.
    • August 31, 1979
    • 422
    Re: 1956 Early Exhaust System
    My 56 Chevy convertible has the 2 hole manifold. You might look at some of the tri-five catalogs and see if something can be adapted and modified by your local muffler shop.
    • Michael A.
      • June 30, 1986
      • 68
      The only way to do it properly is in place. No one sells the correct part. If you call me I will talk you thru it and send you some photos of mine. I did it in place.
      Later Mike (317)729-2418
      • Jim L.
        • September 30, 1979
        • 1804
        OK, I'll ask a dumb question:
        Couldn't you adapt the exhaust pipes for a later 3-stud manifold by just making/scrounging a 2-hole mating flange to slip over the pipes? Is there anything else about the pipes for the early 2-stud manifolds which is actually different?
        Jim
        • Stuart F.
          • August 31, 1996
          • 4676
          Are both the two stud and three stud manifolds the ram horn style? (not the passenger log type manifold?)
          Stu Fox
          • Jim L.
            • 1804
            Stu Fox
            Yes, and that's why it seems (to me, anyway) that one could use the same exhaust pipe with a different attaching flange.
            • Troy P.
              • January 31, 1989
              • 1279
              The 55 Corvette exhaust system should be the same as the 56. 55 had round mufflers.
              • Jim L.
                • 1804
                Troy,
                '56 manifolds, both 2 bolt and 3 bolt, were center dump, ram's horn style.
                '55 manifolds were NOT center dump, ram's horn style. Outlet was offset, forward on one side and rearward on the other.
                The two styles of manifolds take different exhaust pipes.
                Jim
                  • May 31, 1974
                  • 8365
                  when i restored the 56 that went to rick hendrick's collection, it was an early 56 with 2 stud exhaust manifolds. seem to recall i got the exhaust system from corvette central. wherever they came from, they fit perfect. rare occasion when i didn't have to take some pipes to the local speed shop and use their tubing bender. mike
                  • Bryan H.
                    • August 31, 2004
                    • 120
                    I have #76 and a 2 bolt exhaust. I bought the 1st section withouth the 2 bolt flange welded and purchssed a 2 botl flange which I had welded into place.
                    Corvette Cetnral sold both.. Bryan Hepper
                    • Tim E.
                      • March 31, 1993
                      • 360
                      Sheldon - How long ago was it that you talked to Gardner?
                      Just within the last 2 months, an owner of a '56 here in Houston has been working with Gardner on the 2 hole system. They were going to reproduce the 2 hole pipe flanges, the correct orientation, and part of a complete system.
                      I'll get you in touch with the folks involved if that would help.
                      Tim
