73 quadrajet secondary linkage rod configuration? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1696
    I was wondering what the secondary linkage rod looks like, and how it connects correctly to my 73 Rochester quadrajet. It is on the passenger side and controls the back two butterflies. I have an L48 - 4 speed car. Any help would be greatly appreciated.
    thanks
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Russ S.
    • April 30, 1982
    • 2163
    Re: 73 quadrajet secondary linkage rod/need help finding one
    Do you have a junk yard near you? Should be lots of them there.
    • Jimmy P.
      • June 24, 2014
      • 1696
      Does anyone have a picture of the correct one for me to use as a sample. I have checked with guys who have tons of carb parts, but need to see what it looks like. They say there are so many different kind, want to make sure to get the correct one.
      Thanks!
      Jimmy
      1973 Convertible
      L48,M20,N40
      • Russ S.
        • April 30, 1982
        • 2163
        Sent you a PM because I don't know how to post a picture here.
        here is your photo.
          • 11692
          Russ,
          In the upper midwest, like Michigan here, there is essentially zero chance you'll ever find one in a junkyard. Cars rust off the road by 10-15 years of age, and since Quadrajets have been moderately uncommon for 30+ years I haven't seen one in a junkyard since high school.
          Lots of photos on ebay, however. That's often a reasonable reference source if you just want to see a picture.
          Patrick
          • Russ S.
            • April 30, 1982
            • 2163
            It depends a lot on how long a given junk yard keeps older cars. I lived in MN and had a yard close by that I would bet still has considerable of them. At least they did ten years ago.
            • John L.
              • April 10, 2014
              • 36
              Jimmy,
              I believe there is a company in Calif. that sells Qjet parts. On web type " quadrajetparts.com" they may help you.
              John
              • Jimmy P.
                • June 24, 2014
                • 1696
                John,
                Yes, there is. It is SMI Products in Huntington Beach California. Sean Murphy is the gentleman I spoke with and yes, they did have the part I needed. They rebuild and modify Quadrajets and Holleys for racing and the street, as well as sell the carbs themselves.
                Jimmy
                1973 Convertible
                L48,M20,N40
                • John L.
                  • April 10, 2014
                  • 36
                  great, yes Sean is a great person to deal with. My 75 corvette had a carter carb. and I wanted an original. I bought one from them and it worked right out of the box. Just minor adjustments no problems at all. Good luck............ season is here in the northeastern part of the country.
                  John
