1971 Front Side Turn Signal Lens - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    Can you just buy the amber front side turn signal lens? All I can find is the entire housing. Seem a shame to discard the entire bracket because the lens has a crack in it.
    • 15640
    Re: 1971 Front Side Turn Signal Lens
    If your 1971 has an amber lens from St Louis it is unique - one might even say it is rare.
      • 43289
      Paul------
      Are you referring to the turn signal/parking lamp lens (in the grille) or the side marker lamps?
      • Paul C.
        • November 12, 2007
        • 511
        The front side marker lamps.
        • Joe R.
          • July 31, 1976
          • 4552
          Paul,
          Presently the side markers are available from Trim Parts and thru all dealers as a complete assembly. The housing is Die Cast and Chrome Plated with the lens glued to the housing. Approx. price $60.00 per side.
          JR
          PS. The side markers are made by the original supplier to GM.
            • 43289
            Paul------
            The side marker lamp and lens was an assembly. So, there was no separate lens. If you need the lens, then you need the whole assembly.
              • 43289
              JR------
              Now that surprises me. The originals were made by Guide Division of GM. Guide was spun off by GM many years ago and, as far as I know, went bankrupt and out of business several years ago.
              • Joe R.
                • July 31, 1976
                • 4552
                Joe,
                Most die cast emblems and small items were made for Guide by Wolverine Casting which went out of business several years ago. Wolverine Casting was famous for their Lionel Trains!!!!!! Most of their die cast dies were sold to Trim Parts. I should have said, made in the original dies!
                I'm nearly sure that the logo in the new marker lights will have CMD for Custom Mold Dynamics.
                JR
                JR------
