Is this a corvette motor - NCRS Discussion Boards
+ More Options
Posts
  • David L.
    • July 31, 1980
    • 3310
    Re: Is this a corvette motor
    Enclosed is a photo of the page listing engine codes for 1966 Chevrolet models from my 1966 Chevrolet Parts Illustration and Special information Catalog (Oct. 1965).
    Dave
    • Donald H.
      • November 2, 2009
      • 2586
      Originally posted by Mike Ernst (211)
      Actually, the first "1" was simply a spacer. There were not 111,000+ 66's made.
      Yes, I knew the first 1 was not techanically part of the production sequencing number, but what was the need for the leading 1 spacer? I believe the leading 1 was used everywhere the VIN was stamped, at least on the VIN tag, Engine Pad, Transmission and Frame.
      Was it some sort of requirement that VINs had to be 6 digits long?
      Don Harris
      Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
      • David H.
        • November 11, 2009
        • 777
        #18
        First of all thank you all for trying to educate me on this. I do believe I have a good hold on this number and what it means.
        I purchased the pocket guide and the lime book and found it in those.
        It sounds like this would be a good motor to pull out of storage and return to the original car if at all possible.
        The question is what is the maximum I should consider paying for it? If I can get it for cheap, great. But, if not, what would it be
        worth paying for it? Any thoughts?
        • Edward M.
          • November 1, 1985
          • 1922
          #19
          "lime book". The fool that put that book together should have his head examined. And maybe one day soon it will go back into print.
          • Georges C.
            • June 17, 2013
            • 72
            #20
            My car, which I've owned since Oct 1976 and, I personally knew the 2 previous owners as high school classmates, is a vin of 112419 and was final assembly of Jan 21, 1966. It was however a AO Smith body with a T0II0IL 427 (built 01 10 1966) .
            Hope this helps.
            • Bruce B.
              • May 31, 1996
              • 2930
              #21
              The Lime Book is the most comprehensive little book for decoding engine pad stamps, Period.
              In my opinion.
