Inspection Paint 1960 - NCRS Discussion Boards
  • Greg D.
    • June 30, 2004
    • 62
    I'm told that the judging manual is not correct with some items for inspection paint. Where can I find an accurate guide for all parts painted via inspection?
  • Dennis C.
    • June 30, 2002
    • 888
    Re: Inspection Paint 1960
    If you are asking this for judging, I would suggest you contact your team leader to find out if inspection marks will be judged.
    Dennis
    • Thomas H.
      • August 31, 2005
      • 1068
      On my 60, all of the front suspension, rear axle and spring inspection marks were covered by the chassis black out process. I uncovered them when I was cleaning the accumulation of 50 years of grease off using mineral spirits. Once I got through the grease, there was a light layer of paint that was pretty easy to remove. There are references to this in the judging guide.
      This is my experience with a car bought from the original owner. What is widely accepted may be different.......
      Tom
      2007 Z06, Lemans Blue
      • Greg D.
        • June 30, 2004
        • 62
        Thanks but no - not for judging purposes
        • Greg D.
          • June 30, 2004
          • 62
          Tom, thanks for responding. As I said I am aware of the judging guide's comments but have been told that there may be inaccuracies from someone who has done many body offs - all top flighted highly. I am not an expert and rely on this forum and members for their expertise and experience. So I was asking if there is a more comprehensive source.
          • Dennis C.
            • June 30, 2002
            • 888
            Greg,
            We documented many of the inspection marks in the recently updated 61-62 manual. Off hand, I can't think of any that wouldn't apply to a 1960 car.
            Having said that, if you have a question about a specific inspection mark, it might be better to ask about that specific mark. We would then be in a better position to address your specific question.
            Dennis
            • Greg D.
              • June 30, 2004
              • 62
              Dennis, good idea. Front springs: Grey stripe for big brake cars? Otherwise black dot?
              • Gary C.
                Administrator
                • October 1, 1982
                • 17940
                Guys,
                FYI - front suspension paint marks are mainly chassis identification (part) paint identification marks. Visual aids to an installer to easily identify part applications and placement on the assembly. Example on the tire rods; left is one color and right is another. That's to make sure the tie rods have opposite right/left threads.
                Yellow paint generally denotes a Corvette part since there were 3 assembly plants at the St.Louis facility.
                Inspections paint marks are for an example of the rear end flange nut, which indicates the nut was properly torqued.
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Thomas H.
                  • August 31, 2005
                  • 1068
                  From my 60. Grey marks on spring. Visible on two coils after cleaning off the black overcoat. Evidence of it on some of the other coils also. Like they took a brush and just went down the spring.
                  • Dan H.
                    • July 31, 1977
                    • 1372
                    Greg, there is a ton of information in old Restorer Magazines, order a set for your car on DVDs and research away!
                    Dan
                    1964 Red FI Coupe, DUNTOV '09
                    • Dennis C.
                      • June 30, 2002
                      • 888
                      Greg,
                      i would expect expect to see front springs painted black with a grey stripe approximately 3/4" wide, that looks like a brush stroke.
                      Gary makes a great point about the difference between inspection marks and paint marks used to distinguish parts at the factory or manufacturing plant.
                      Dennis
                      • Patrick S.
                        • January 1, 1988
                        • 209
                        Lots of good information in the CHASSIE RESTORATION GUIDE available in the NCRS Store.
