66 - Headlamp Switch - NCRS Discussion Boards
+ More Options
Posts
  • Stephen L.
    • August 29, 2007
    • 205
    on a 66, i am looking to swap out the headlamp (headlight) switch
    1 - what modern day tool is good for getting the "ferrule" off?
    2 - from the diagram in the service manual, it looks like there might be a clip on top of the assembly that hangs it onto a little ledge? - or once the ferrule is off is it just loose?
    3 - any tips on getting the old wiring socket out w/o cracking/breaking it? - is there some kind of equivalent to penetrating fluid that softens brittle plastic up a bit to avoid breaking it? (the service manual says using a screwdriver is ok to pry it apart...)
    when i refer to the service manual i am looking at the pages attached
    thanks!
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 66 - Headlamp Switch
    That's a chevy II page.
      thanks!
      Stephen -
      They make a tool for that ferrule nut (the small one in the photo below), or you can make one by grinding down a socket, or you can use the tips of a pair of needle-nose pliers.
      • Stephen L.
        • August 29, 2007
        • 205
        Thanks Guys - made the swap last night
        I had dash lights and thougth the reostat was bad on the old switch
        new one (which is a rebuilt original) still provides no dash lights
        what would be the next trouble shooting step to figure out what is wrong?
        • Russ S.
          • April 30, 1982
          • 2162
          Dumb question but have you checked the fuse?
          • Stephen L.
            • August 29, 2007
            • 205
            Even dumber answer: no!!
            will do
