1965 E Brake handle shaft removal - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    I am cleaning the e brake assy. and I want to remove the brake pull shaft . It has a pin to stop the travel that appears to be pressed in . Can it be pulled out or is there threads . I thought I'd ask before I broke it .
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 1965 E Brake handle shaft removal
    Good idea to ask first I didn't ask and broke the pin on my car. It is pressed in and can be driven out. Just don't twist or it will break.
    • Jim S.
      • March 1, 1986
      • 1408
      That's How I remember mine, pressed in .Straight in and Straight out . The Square top is only for alignment to the switch , it is not a bolt head.
      Jim
      • Bill W.
        • March 1, 1980
        • 2000
        Thanks Bob & Jim I got it out with no problem .
        • Wayne Y.
          • March 10, 2015
          • 41
          Hi,
          I'm doing the same thing on my 63 E-brake handle. I'm looking at it, and wondering what the best way is to get the pin out? Any advice, since you just did it? ; )
          • Bill W.
            • March 1, 1980
            • 2000
            Wayne . Im not sure about a 63 but on my 65 there is a hole on the bottom side of the housing so you can drive the pin straight out .
            • Wayne Y.
              • March 10, 2015
              • 41
              Thanks Bill - that appears to be the same with my '63. I'll give it a go this weekend...
