Black paint for 66 interior dash brackets - NCRS Discussion Boards
  • Jeremy R.
    • May 23, 2012
    • 137
    I see SEMS Trim black is used almost everywhere with a C2 black interior (dash, gauges, steering column, console, fiberglass pieces), but what I would like to know is Trim black is the right black for the hood release and brake release brackets, and also the metal coupling that connects the a/c duct work together under the passenger side of the dash for a/c cars?
  • Joseph T.
    • March 1, 1986
    • 169
    Re: Black paint for 66 interior dash brackets
    Yes to all your questions.
    • Jeremy R.
      • May 23, 2012
      • 137
      Thanks Joseph
      • Marco H.
        • March 1, 2002
        • 218
        The AC duct coupler piece on the passenger side has been observed to be somewhat glossier than SEMS trim black. Also, you didn't state, if you are working on a coupe or convertible. The coupe halo panel along with the upper door frames, headliner trim and windshield pillar trim pieces were sprayed "gloss" black (un-buffed, not representing a exterior paint finish.) Very often, restored cars have all interior pieces refinished in the same paint and do not necessarily represent a typical factory appearance.
        Hope this helps.
        Marco
        • Gary B.
          • February 1, 1997
          • 7070
          Marco,
          Excellent points. The interior of a coupe would definitely not be factory correct if everything was sprayed SEM trim black.
          Gary
