65 close ratio transmission - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    My 65 BB lost its original transmission back in its drag racing days . It has a 66 close ratio in it now with a right side speedo cable . I have a correct 65 tail shaft housing . can I just switch the housing or do I need to also change the tail shaft ?
    • 43277
    Re: 65 close ratio transmission
    Bill------
    You can just change the extension housing. It will work perfectly with the 1966 transmission.
    • Bill W.
      • March 1, 1980
      • 2000
      thanks Joe
      • Mike T.
        • January 1, 1992
        • 569
        My 65 had a drivers side speedo location and I wound up changing it for a passenger side version from Auto Gear. I'm only going off memory here but recall that the drive gear will need a slight bit of tweaking to line up when switching from one side speedo plug to the other side, maybe not.
        Mike T. - Prescott AZ.
        • Wayne M.
          • March 1, 1980
          • 6414
          Bill -- I'm confused; the passenger side tail housing # ....584 is the correct one for all of '65 and '66 (and '67). So what tail housing casting number is on your '66 unit ?
          • Jim D.
            • 2885
            My 65 has the #584 pass. side speedo drive tail housing. That's how it came from the factory. trans 3.jpg
              • 43277
              Wayne------
              I thought that early 1965 used the 3846429?
              • Jim D.
                • 2885
                Wayne------
                Since the O.P. has a BB car, "early" cars has nothing to do with it.
                • Bill W.
                  • March 1, 1980
                  • 2000
                  Ok Wayne now Im confused . I looked in the assy. manual it says it should have a pass side connection . On the internet it says 63 to 65 have a 3846429 left side cable . and for 66 a 3851325 . my car has a 66 3885010 main case (with a 66 vin #) and a 3857584 tail housing with a right side cable . So do all 65BB have the 584 rt side cable ? I have two complete 64 /65 trans.with pat. numbers and 7/8 bore and one has a 584 and one has a 429 tail ??? If the 584 rt side is correct thats great .
                  • Robert D.
                    • April 1, 2003
                    • 305
                    Bill, as mike said if you find you have to change the side the speedo cable comes out on the only thing you need to change is the position of the speedo gear. you will see the area where it sits on the tail shaft on the right side speedo cable the gear sits towards the rear of the area on the tailshaft on a left side speedo cable its placed towards the front of the area. be careful trying to move it it is very soft and easily damaged i would press it off then heat it up with a tourch it expands very easily and once heated you will find it will slipon pretty easy and once it cools will be very tight pretty easy to do
                    bob
                    • Wayne M.
                      • March 1, 1980
                      • 6414
                      Wayne------
                      Joe -- that's one of those A. Colvin (Chevrolet by the numbers) nuggets that will not die. Chevrolet stated about the pasenger side takeoff revision both in their 1965 New Product Manual (July 1964) and Chevrolet Service news (Sept 1964) that:
                      "the 4-sp trans extension housing and mainshaft are revised to provide for a right hand speedo take-off. (Also) applies to Chevelle, Chevy II and Corvette".
                      • Mike T.
                        • January 1, 1992
                        • 569
                        Bill - As Robert pointed out, that drive gear bruises easily, especially if the person pressing it on get's a little carried away. The non-original Muncie in my 65 Smallblock Coupe was in need of a rebuild and just before we pulled it out, the speedo quit working. Turned out that one of the 'many' previous owners didn't line the drive gear up correctly and as you can see from this pic (gear on left), and beat it up while trying to get it in place.
                        The replacement drive gears, from places like D&L trans in NY are pretty cheap if you find you need to replace yours.
                        • Ray K.
                          • July 31, 1985
                          • 375
                          Bill,
                          My '65 Corvette 396 has the #3857584 transmission extension housing with the right side speedo cable attachment.
                          Ray
                            ALL '65 Corvette Muncies have the 584 tailhousing with the passenger side speedo drive. Period.
