67 flasher bracket position - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 1985
    My March 67 convertible had a flasher held in a bracket screwed to the drivers side radio side panel as shown in the pictures. I don't remember a flasher in that location on other 67's I used to own, but the bracket looks like a factory made piece. Is this flasher for the 4-way flasher. Where should it go if this bracket is not factory?
  • Ara G.
    • January 30, 2008
    • 1108
    Re: 67 flasher bracket position
    Pat, That's for the round 323 flasher. Yellow, plastic, NON-DOT. Also need capacitor with blue/gray (IIRC) paper insulator. ARA
    • Patrick B.
      • August 31, 1985
      • 1985
      Ara--- Is this an original bracket in the correct location? Or should the flashers you mentioned be mounted under the dash somehow. The flasher that was in the bracket had a clear cylindrical housing that allowed you to see inside of it, so it must have been a replacement part.
      • Ara G.
        • January 30, 2008
        • 1108
        Yes, but turn it 90 degrees so it's clocked up/down. The flasher faces with the top of the flasher downwards, the capacitor and paper insulator, then the wire connection.
        • Patrick B.
          • August 31, 1985
          • 1985
          Thanks Ara. I never noticed this bracket in the four other 67's I had over the years.
          • Donald A.
            • February 28, 1987
            • 243
            Here is the bracket and flasher in my 67. The Judging Guide (5th Edition) states "A turn signal flasher is installed in a black phosphate plated metal clip on the driver's side radio side panel. The clip is attached with a single screw. Either Tung Sol yellow plastic, not painted yellow, #323 or Signal Stat #145 flashers were used." My car has the 145 Signal Stat, it still works
            • Ara G.
              • January 30, 2008
              • 1108
              Great picture Don
              • Patrick B.
                • August 31, 1985
                • 1985
                Thanks for the picture Don.
                • Leif A.
                  • August 31, 1997
                  • 3602
                  I apologize for hi-jacking this thread, but does anyone know who sells a correct flasher with the wax paper capacitor attached for a radio equipped car as pictured in the TIM&JG? I pretty thoroughly checked Paragon and LIC.
                  Leif
                  • Donald A.
                    • February 28, 1987
                    • 243
                    Originally posted by Leif Anderson (29632)
                    ...who sells a correct flasher with the wax paper capacitor attached for a radio equipped car as pictured in the TIM&JG?
                    Hi Leif,
                    The capacitor is a separate item from the flasher. The capacitor is LICS part# 53-03F, pictured below. The flashers are non-DOT no longer made, repros are available but with DOT markings, originals show up from time to time on eBay, forum ads etc.
                    • Leif A.
                      • August 31, 1997
                      • 3602
                      Thank you, Don
                      Leif
