67 L36 intake manifold gaskets - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 804
    Regarding Flight Judging, do the intake manifold gaskets need to conform to the intake like small block gaskets do? I am guessing they get orange overspray as well?
    Thanks guys,
    Lawrence
    • 43258
    Re: 67 L36 intake manifold gaskets
    Thanks guys,
    Lawrence
    Lawrence------
    Your best bet for judging purposes are the reproduction gaskets offered by Paragon and their distributors. These are very good sealing gaskets, too.
    • Lawrence S.
      • April 1, 1993
      • 804
      Ok thanks Joe
      • Joe R.
        • May 31, 2006
        • 1822
        Hi Joe,
        Now that Lawrence's question has been answered, I thought I might hijack the thread slightly with another question. Which is, is your answer true for all 427's (L72 specifically in my case).
        Thanks!!!!
        Joe
          • 6950
          Larry, The gaskets will show over spray on the rubbers, but the problem is the reproductions are missing the tabs with the GM insignia on the end of the rubber seals of the intake.
          • Wayne M.
            • March 1, 1980
            • 6414
            Compare the intake contour to the gaskets (both oval & square port shown) from a GM late '60s service kit, and you may be able to tell where gasket material overlaps, hence subject to factory overspray.
            c
              • 43258
              Originally posted by Joe Raine (45823)
              Hi Joe,
              Thanks!!!!
              Joe
              Joe------
              Yes.
                • 43258
                Edward-------
                Yes, the only way to get that nuance is to find a set of NOS gaskets. However, some later NOS gasket sets, while having the GM-embossed end gaskets do not have correct side gaskets.
