67 BB Oil Pan Bolts - NCRS Discussion Boards
67 BB Oil Pan Bolts
  • Kerry A.
    • August 31, 2004
    • 153
    67 BB Oil Pan Bolts
    I'm in the process of having my 427/435 engine rebuilt and I have a question regarding the oil pan mounting bolts. According to the judging guide there is no mention of the bolt type or markings. Upon researching various vendors, I found there is a set of all recessed/indented head bolts with E and L markings available. Another vendor offers 2 standard hex head bolts and the remaining bolts are recessed/indented with the E and L markings. Two of the bolts in both kits are longer and these are used to attach the oil pan to the timing cover. Is there a right and wrong head and marking on the bolts for this application? Thank you.
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 67 BB Oil Pan Bolts
    Kerry,
    According to the TIM&JG 1967 fifth edition on page 192, section titled "Oil pan & drain plug". "ALL pans are a two step design - a shallower forward area which curves down to a deeper flat bottomed sump at the rear. Original pans have steel reinforcements spot-welded to each corner of the pan. The pan is attached to the block along the perimeter with 7/16" indented hex head bolts with captured serrated washers, except for the bolts passing through the corner reinforcements, which are 1/2" head size. An L or and E head mark is commonly seen."
    Leif
    • Kerry A.
      • August 31, 2004
      • 153
      Leif,
      Thank you for your reply. Not only did you answer my question you pointed out a deficiency. My 67 TIM&JG is the fourth edition and there is no mention of the bolts on page 137. I think it's time to upgrade.
      • Leif A.
        • August 31, 1997
        • 3645
        Originally posted by Kerry Alligood (42585)
        Leif,
        You're welcome. And, you will really appreciate the updates in the fifth edition...terrific guide.
        Leif
        • Rich P.
          • January 12, 2009
          • 1361
          Just for reference here are some pictures of Hardware for big blocks There could be loads of different headmarkings for 67 the E and L are just some well recognized ones.
          • Kerry A.
            • August 31, 2004
            • 153
            Rich, Thank you for the pictures. The number of head markings is mind boggling. I guess the bottom line is the bolt itself was the most important to GM than the head marking. Now however for collectors, the head marking are the most important. Thanks again.
            • Wayne M.
              • March 1, 1980
              • 6414
              Here's the oil pan bolts off a mid-May '65 cast 396. Sixteen of them were the "U"; one a recessed "L", and 2 odd-balls.
              • Kerry A.
                • August 31, 2004
                • 153
                Thanks Wayne. I guess it goes to show regardless of how diligent collectors are and how educated the judges are, there is a lot we really don't know or understand. Thank you for your reply. I hope this thread helps others.
                  Kerry -
                  NO ONE at GM paid ANY attention to headmarks - with multiple suppliers for individual fasteners, all they cared about was part numbers. The headmarked bolts in the line-side bin may be gone, replaced, or mixed by tomorrow.
                  • Kerry A.
                    • August 31, 2004
                    • 153
                    If you really want to see a jigsaw puzzle of bolts work on a an early 2000's Jeep. I swear people stopped at Ace on the way to work. Metric and standard mixed. It's a head scratcher.
