'66 original rear valance lower bolts - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I'm looking for either a picture or a description of the original bolt & nut that attach the lower part of the rear valance on each end. I've seen several different types advertised as correct. I believe the bolt is the washer head type as well as the nut. I've seen nuts with "RBW" that look correct. As expensive as these small," original" items are getting, I want to know I'm looking at originals.
  • Joseph T.
    • March 1, 1986
    • 169
    Re: '66 original rear valance lower bolts
    Rob,
    I believe these are the bolts you are looking for- Richard Fortier, a Driveline advertiser, has them.
    • James W.
      • December 1, 1990
      • 2676
      Here are two as installed pictures on an unrestored car. It is a '65 but I doubt they would have changed.
      James
      • Ara G.
        • January 31, 2008
        • 1108
        Jim's picture shows the correct installation of them as well. Other headmarkings are RSC, EL, E. ARA. Obviously I agree that the pictures Joe was nice enough to post are IMO correct, original valance bolts. ARA
        • Harry S.
          • July 31, 2002
          • 5346
          Here is where else that nut is used.....
          49 1 B5.00 9 2 4728063 Nut
          800 Gas Tank Door, Rear Body Emblem & Filler Panel & Tail Pipe Bezel
          92 1 E4.00 9 2 4728063 Nut 35-50 lbs. In. 837 Side Door Vent Window & Molding
          101 1 E13.00 11 2 4728063 Nut 35-50 lbs. In. 867 Side Door Vent Window
          The Washer.....
          49 1 B5.00 8 2 Washer
          800 120392 Gas Tank Door, Rear Body Emblem & Filler Panel & Tail Pipe Bezel
          93 1 E5.00 7 4 Washer
          800 120392 Side Door Window Mechanism
          133 6 C1.00 7 1 Washer
          800 120392 Accelerator - Rod, Lever & Spring
          230 C07 6.00 16 2 Washer
          867 120392 Hard Top - Moldings & Top Attachment
          This was the only location for the bolt....
          • Russ S.
            • April 30, 1982
            • 2163
            These bolts don't appear to have an indented head as do the ones in the post by James.
            Originally posted by Joseph Tansey (9727)
            [ATTACH=CONFIG]58624[/ATTACH]
            Rob,
            • Rob A.
              • December 1, 1991
              • 2126
              Thanks for the replies and the pics...I appreciate it.
