Any Nylon tires with no flat spot issues? - NCRS Discussion Boards
  • Daniel Y.
    • September 30, 2002
    • 186
    Re: Any Nylon tires with no flat spot issues?
    Thanks Russ - do you know if they are Kelsey or Coker or some other Distributor?
    Dan Young
    65, 67 Duntov x2
    66 bowtie x 2
    71 LT1 TF
    90 ZR1 McCelland
    03 Anniverary
    06 Z06
    • Daniel Y.
      • 186
      I obviously got confused. I just got off the phone with John - owner of Kelsey Tire if it says Polyester it has to be
      Dan Young
      65, 67 Duntov x2
      66 bowtie x 2
      71 LT1 TF
      90 ZR1 McCelland
      03 Anniverary
      06 Z06
        • 15706
        Originally posted by Daniel Young (38681)
        Micheal. I asked Coker regarding the "Polyester" brand - asked maybe that was why they ride so good. That told me regardless of what is on the tire they are all Nylon - made in the same factory but different molds. I thought the same thing as you but was disappointed to find out they are not really Polyester
        Polyester is not a brand. It is a tire cord material, and the cord material and number of plys must be molded into the sidewall per DOT regulations.
        I believe a bias ply tire mold can be used build a tire with either rayon, polyester, or nylon cord, except the material placard would have to be changed to reflect the type of cord material.
        • Russ S.
          • April 30, 1982
          • 2163
          No, I don't. I have had them for about four-five years I think Kelsey does Goodyears tires and Kelsey has Firestone.
            • 43295
            Well then they are violating federal law, because my 7.75X15 BFG Silvertowns clearly stated on the sidewall they were of polyester cord construction. So now Coker now longer has BFGs that are polyester cord? My tires are about 5 years old, so maybe they have changed?
            Added picture of sidewall, I also have a set of 6.70X15 Coker BFG Silvertowns that are the same polyester construction.
            Michael-----
            Yes, were it not for that requirement I would think that they would manufacture all the tires using polyester cord material. I would expect the only reason they use nylon cord material is because folks want the original sidewall saying nylon cord and the only way they can do that is to actually use nylon cord.
              • 15646
              Originally posted by Russ Steinhaus (5540)
              No, I don't. I have had them for about four-five years I think Kelsey does Goodyears tires and Coker has Firestone.
              There Russ; I corrected it for you.
              When John Kelsey first was first working on the F-70 15 Goodyears for the early C3s I was NTL and he and I had this discussion.
              John: "Does the sidewall have to say 'Nylon Cord'?"
              Me: "Yes, if you want the tire to get full credit."
              John: "Then it will have to be made of nylon."
              Me: "And your problem is?"
              There it is. If you don't like flat spots buy another tire to drive on. We all remember the "old days" with fond nostalgia; but we too soon forget reality.
              • Russ S.
                • April 30, 1982
                • 2163
                Thanks Terry. I hadn't realized the mistake.
                • Bill C.
                  • July 15, 2007
                  • 904
                  i found that if you use the rolling tire jacks under each wheel, it will keep the flat spotting down to a minimal.
                  I think that because the tire jacks are rounded/cupped shape, it helps to keep the tire in its "normal" shape.
                  I have used them for years and it helps my cars a lot. The benefit is really noticeable during cold months.
                  And if there is a flat spot, its gone in 5 minutes anyways....
