'96 A-arm cotter pins - NCRS Discussion Boards
  • Paul S.
    • December 13, 2013
    • 83
    Is this the correct way to bend the cotter pins on the lower and upper A-arms on my '96 CE?
    Paul Schwack (59307)
  • Floyd B.
    • November 1, 2002
    • 1054
    Re: '96 A-arm cotter pins
    Hi Paul,
    Here is a pic of mine. I'm 99% sure this hasn't been touched since installed at the factory.
    "Drive it like you stole it"
    • Paul S.
      • December 13, 2013
      • 83
      Thanks Floyd, that helps a lot...Paul
      • Pat M.
        • April 1, 2006
        • 1588
        The originals on my 96 look similar to Floyd's - bent down and slightly spread apart.
        • Ed N.
          • May 16, 2010
          • 1003
          Mine are like Pat's and Floyd's.
          Ed Nieves
          NCRS #51799
            • 43291
            This type of cotter pin bending is accomplished by using a tubular tool slightly larger in ID than the "across-the-points" OD of the nut. I have no doubt it was used by the factory as a "quick-and-dirty" means of bending over the cotter pin. However, in my opinion, it's an absolutely bogus way to do it.
              • 15646
              Joe,
              In the early C3 years, like your 1969, the ball stud cotter pins were bent this way to allow clearance for the wheel alignment machinery. I am not sure this was the case for C4s, but it was the case for my SALA 1995 Caprices.
