Which factory installed the Water Pump & Starter? - NCRS Discussion Boards
  • Bob P.
    • June 30, 1998
    • 143
    I have a quick question about the installation of the water pump, fan and fan clutch installation as well as the starter. Were these installed at the engine assembly plant or at St. Louis on 1971 models with small block engines? Trying to determine if the dates on these components should be closer to the engine assembly date or the vehicle build date?
    Bob Puls, 30633
  • Edward J.
    • September 15, 2008
    • 6960
    Re: Which factory installed the Water Pump & Starter?
    Bob, I am pretty sure the engine build date is what your looking for those dated parts. since its a small block those parts are generally a few weeks difference from the stamp date on the engine, but could be few days later or closer.
      • 43290
      Bob------
      The waterpump was installed at the engine plants. The starter was installed at St. Louis.
      • Bob P.
        • June 30, 1998
        • 143
        OK Great, so the water pump and the fan clutch should be dated before the assembly date of the engine and the starter before the assembly date of the car?
        Bob Puls, 30633
          • 15644
          Fan clutch, and fan, were installed at St Louis.
          TIP: If the part number shows up in the AIM (Assembly Instruction Manual) the part was installed at St Louis.
