1958 Spare Tire and Wheel - NCRS Discussion Boards
  • Eric A.
    • December 21, 2012
    • 126
    Need some guidance based on Judging. I installed my spare tire today and notice the cover setups up about 1/2. After reading the judging manual this is common with Reproduction tires. The wheel is original dog bone steel wheel with all the right marketings. The tire is the original specs from COKER tires in Tennessee - Firestone 2 1/2 whitewall tire. What are people doing to make the board mount flush ?
    Eric
  • Thomas H.
    • August 31, 2005
    • 1068
    Re: 1958 Spare Tire and Wheel
    Eric
    Let some air out of the tire..............
    2007 Z06, Lemans Blue
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11364
      Yes, that's the only thing you can do Eric. When driving to judging, leave it full. When you get there before going into the show field, let some out. Take a 12v compressor with you so you can fill it back up for the ride home.
      • Eric A.
        • December 21, 2012
        • 126
        Thanks Guys.. I thought about that but I was thinking could it be that easy for judging reasons.
        Eric
        • Gary H.
          • June 30, 1980
          • 155
          If you are being flight judged the spare is NOT judged in the car, so its not an issue. It only becomes a possible problem if you are having your car PV'd, then the board should set flat.
          • Donald H.
            • November 2, 2009
            • 2589
            On my 60 I had to let most of the air out of the tire to get the board to lay flat. I wanted the board to fit correctly even though it is not judged in the car. Judges at Regional and National didn't say anything about it being flat. Since they readily recognize the repro tires, they don't spend a lot of time looking at them.
            Don
            Don Harris
            Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
