QUADRA-JET Brass or Nitrophyl Float? - NCRS Discussion Boards
  • Rich C.
    • January 1, 1994
    • 383
    Any thoughts on the pro/cons of a brass vs. nitrophyl carb float in my '73 Quadra-Jet? I always assumed I had no choice but the nitrophyl variety, but I have access to the brass variety. I've seen where the brass ones can develop pin holes and fill up, but other than that?
    1973 LS-4 454 coupe owned 24 years
    1996 LT-4 C.E. coupe owned 16 months
    Sierra Nevada Celebration Ale currently on tap!
    • 6948
    Re: QUADRA-JET Brass or Nitrophyl Float?
    Rich, I have rebuilt many carburetors over the years and have used the factory style floats with out problems, brass is also trouble free, it maybe that the the newer fuels w/ethanol brass maybe a better choice.
    • Paul D.
      • September 30, 1996
      • 491
      Rich, would you mind sharing your source for brass Q-Jet floats? Do they offer ethanol resistant kits? Chip.
      • Domenic T.
        • January 29, 2010
        • 2452
        I vote for the brass as a better choice. When the brass go's bad it happens fast. When the foam starts to fail it takes a while and I have seen guys change plugs, jets, and have all kinds of problems only to find a half soaked foam float.
        I buy brass when I rebuild. The aviation carbs were switched to foam only to be switched back to a reinforced brass float.
        See this also on tank sending units.
        Dom
        • Arland D.
          Moderator
          • July 31, 1980
          • 427
          Rich,
          I went with brass on my Q jets for the reason mentioned - if it fails, you'll know right away.
