Engine Pad paint removal. - NCRS Discussion Boards
  • David K.
    • September 30, 1992
    • 281
    Hi Guys;
    The engine pad on my 65' was painted Chevy orange along with the rest of the block during restoration. I would like to remove it prior to judging this spring. What would be the best 'product' to use. I'm assuming the paint is enamel.....
    Thanks in advance. David K
  • Joe R.
    • July 31, 1976
    • 4552
    Re: Engine Pad paint removal.
    David,
    Any paint thinner will do an excellent job as long as you apply just to the surface. You should have no problem. You can clean around the edges with a Q tip.
    JR
    • Kenneth B.
      • August 31, 1984
      • 2091
      Uss a paint stripper and a cotton swab.Oil the pad after all the paint is off
      • Dennis O.
        • December 1, 1988
        • 438
        I used a wooden toothpick soaked in paint remover to get the last of the paint out of the letter and number stampings.
        • Pancho T.
          • July 31, 1993
          • 238
          I agree. Bare surface can rust quickly
          • David K.
            • 281
            Thank you very much for the advice. Regards; David K
            • Donald A.
              • January 7, 2013
              • 239
              I soaked a small part of a rag with B-12 carb cleaner and held it in place to soften the paint. Then a light rub with repeated fresh moistend B-12 rag.
              • Brian D.
                • April 30, 1999
                • 425
                I did exactly what Ken has described. Works quite well.
                B.D.
                  • 15706
                  Most engine paints are lacquer based, so lacquer thinner is likely the best solvent other than paint remover. A Q-tip and toothpick as advised should work well.
                  WD-40 or Armorall will protect the pad from corrosion, but won't pick up dirt as readily as oil.
                  • David K.
                    • 281
                    Thanks Duke;
                    Happy Holidays to everyone on the board - all the best for 2015 !
                    Regards from Montreal; David Kalaydjian
