1958 Distributor - NCRS Discussion Boards
1958 Distributor
  • Benjamin C.
    • July 31, 1994
    • 134
    1958 Distributor
    What is the difference between a 914 and a 908 distributor? Also what date did the change take place?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11356
    Re: 1958 Distributor
    This document should show the diffs, but as to the the date I have no idea, maybe Noland's book?
    Rich
    • John D.
      • December 1, 1979
      • 5507
      Benjamin, Consult with Don Baker & of course your Tim leader Tim Mickey on a more accurate date on the change over. I can report that the 908 was used to at least all of Jan 1958. At least is the key word.
      I see a fair amount of restored '58 FI's cars running '914's when in fact that should have the '908.
      You cannot go by the date on the ID tag of the '914's and use the distributor as such and call it correct.
      For example we have seen early'914's dated 7J10, 7K25, 7M14, etc. Delco Remy was stocking up but they first used up a ton of the left over '908's. John D.
