resto tip - NCRS Discussion Boards
resto tip
  • Mike M.
    • May 31, 1974
    • 8404
    resto tip
    i've stripped the paint/grease/undercoating from 8 c-1's and a dozen c-2's over the years. most, if not all paint strippers contain methylene chloride, which also does a fine job of stripping the outer layer of your skin should it make contact. being the thrifty type (some would describe it as cheap) i've used disposable surgeon's gloves(cheaply removed from our office). the free gloves are composed of latex or non-latex synthetic materials. these babies are no match for methylene chloride or lacquer thinner(which is my last solvent when removing the crap off old corvettes). Recently i discovered a glove that stands up very well to the methylene chloride and not too bad to lacquer thinner. these puppies are re-usable (frugality?) . they go by the name THICKSTER by the SAS safety corp. i get them at the local parts store. one downside to the THICKSTER----they are about 35 bucks for 25 pair. mike
  • Harry S.
    • July 31, 2002
    • 5338
    Re: resto tip
    Mike, Thanks.
    What model did you get 6605, 6604, 6603.........? There is a bunch up on Ebay.
    Unless the 4 digit number refers to size and quantity and not protection.
    • Michael J.
      • January 27, 2009
      • 7161
      Re: resto tip
      Interesting, I will have to try those. I have always used the thicker nitrile gloves for these kind of things.
      • Mike M.
        • May 31, 1974
        • 8404
        Re: resto tip
        6004 is xl. i usually take a large size glove but these xl's a real tight trying to remove them i'll get xxl next time. mike
        • Dan A.
          • May 31, 1974
          • 1073
          Re: resto tip
          O'Reilly Auto Parts has the XXL #6605 for $19.99.
          Walmart website has them reduced to $16.85 from $28.95 but $6.97 shipping for the XL 6604. Maybe a good deal if they have them in the store at this price.
          • Bill S.
            • April 30, 2002
            • 154
            Re: resto tip
            Try WalMart ship to store for free shipping.
            Bill Strobel
            Owner Independent Towing
            Fayetteville, NC
            1979 Corvette White/Red L-82 4 spd
            Only 4,200 miles
            Do It Right or Don't Do It At All
            • Joe R.
              • July 31, 1976
              • 4552
              Re: resto tip
              Mike,
              For stripping the undercoat and road grime a friend of mine and restorer from the bootheal of Missouri recommended to me (Easy Off Oven Cleaner). It works great!!!! It's thick and when left on for about 30 minutes it takes the stuff off in a couple of of coats. And yes, you better have the gloves on as this stuff will burn your skin OFF!
              JR
              • William D.
                • April 1, 1993
                • 101
                Re: resto tip
                Hi Mike - Thanks for the tip. I also use a rebreather now, as when I stripped the undercoating off my convertible I ended up in the ER after breathing the stuff in!
                1965 Conv 327/365HP 4 sp, 3.73, KO's, pb 96.6 pts
                1965 Coupe fuelie, F40, 411's, teak/tele, 32K, 98 pts
                • Stephen B.
                  • April 1, 1988
                  • 879
                  Re: resto tip
                  Great information Mike. I am cheap also. lol
                  • Peter S.
                    • March 28, 2012
                    • 327
                    Re: resto tip
                    Hi Mike,
                    Methylene chloride is nasty stuff, and will degrade any form of latex glove fairly quickly. Back in my Dow Chemical days, vinyl gloves were strongly recommended when dealing with MeCl. Maybe not for the "thrifty," but if you consider you can wear them multiple times before disposing them, they do provide some value and maximum protection.
                    And yes, they are as uncomfortable as they look. I would wear a pair of latex gloves over the top of them just to form them a bit better to my hands.
