1960 coil bracket bolts - NCRS Discussion Boards
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    What would be appropriate head bolt markings on a 1960 coil bracket? Any difference on a fuel car?
  • John D.
    • December 1, 1979
    • 5507
    Re: 1960 coil bracket bolts
    Lynn, I have seen several logos/brands used on the fuel car coil bracket. "WB1c" appears to be the most common. I also see "UR"
    and just a maybe on RBW or RSC.
    Remember you need two different lengh bolts for a fuel car baseplate to coil bracket. The one in the center is shorter. If you use a 5/8" long one in the cener you may break out the boss on the other side of the baseplate and have serious engine issue.
    I wish I could purchase a qty of WB1C's for little bucks. John
    • Lynn L.
      1953-55 Team Leader
      • February 1, 2000
      • 162
      Thanks for recommendation, Really appreciate "heads-up" on length!
      • John D.
        • December 1, 1979
        • 5507
        You are most welcome Lynn.
        If the baseplate/intake is off the engine look at the bottom side of it. You will see a boss hanging down for the one coil bracket bolt. I have seen my share of cracked bosses ready to fall off into the engine. All because of a bolt that's too long. John
