67 L36 Exhaust Manifold repair - NCRS Discussion Boards
  • Joe R.
    • May 31, 2006
    • 1822
    Re: 67 L36 Exhaust Manifold repair
    Jerry McNiesh? (sp?)
    Hi Rich,
    You're in the ballpark, it's MacNeish. Here's the web site:
    Joe
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11345
      Originally posted by William Ford (50517)
      The Z28 (has a video showing setting drag record in old Reliable") and carb restorer guy, having a brain freeze for name, repairs cast iron manifolds, He shows some on his web site. What's his name, guys?
      Originally posted by Joe Raine (45823)
      Hi Rich,
      Joe
      I got on base. When I first replied, I spelled it "McNeish"....then I remembered ....."I before E except after C".....and changed it. I always get McDonalds and MacDonalds wrong too.....At least I'm consistent.
        • 43258
        #18
        Hi Rich,
        Joe
        Joe------
        Jerry's web-site shows a "very rare" 1969 Z-28 right side manifold that was weld-repaired. The thing I don't understand is what's so rare about this manifold that would justify a weld-repair. This same manifold was used on many other 1969 and later small block applications. Of course, maybe there's some nuance I'm missing as I really have no Camaro experience.
        • Lawrence S.
          • April 1, 1993
          • 804
          #19
          Joe------
          I don't think there is anything "rare" about that manifold. I once owned a 69 Camaro 350 2 barrel three speed car that had smog and those manifolds were on the car. If the car was a straight drive, small block in 1969 it had smog. So there were many many of those "rare" manifolds in the market.
          • William F.
            • June 9, 2009
            • 1364
            #20
            Point is he REPAIRED it.
            • Wayne M.
              • March 1, 1980
              • 6414
              #21
              With all that's been said about repair methods and durability, would you consider this hole an easy cast iron repair? Manifold in pics was on my car when I bought it and drove back to Canada. It's an "828" (RH) with what looks like a casting date of G_2_7; it has the A.I.R. holes.
              Thought I smelled exhaust while driving but couldn't figure out where it was coming from.
              This hole was probably caused by "big-block-itis" [thrashing the go pedal] and worn motor mounts, allowing the engine to twist until contacting the idler arm bolt at the frame attach bracket.
              Or, is it just a door-stop ?
                • 43258
                #22
                William------
                That's obvious and not in question. The question was why did he call it "very rare"?
                  • 43258
                  #23
                  Wayne------
                  That one I might take a chance on a weld repair. Also, if there's enough thickness of material at the hole, you might be able to drill and tap it for a very short countersunk head screw. Then, carefully grind the the screw head flush with the manifold.
