1970 454 with ac dip stick question - NCRS Discussion Boards
  • Kenneth B.
    • August 31, 1984
    • 2091
    I need to know the length of the dipstick on a 1970 454 with AC. I know it is supposed to have a black top like the small blocks & there is a long & short tube & both were used on the 454 so were there 2 different lengths when the long & short tubes are used. Guide doesn't say what the lengths are.
    • 43263
    Re: 1970 454 with ac dip stick question
    Kenneth------
    I don't think that there was a difference between C-60-equipped LS-5 and LS-5 not equipped with C-60. Some folks think so, I do not. However, there was a difference between early LS-5 and later. Early cars used a dipstick which was 17-13/32" from seat to "full" mark and 19" from seat to "add" mark. Later 1970 used a dipstick that was 22-11/16" from seat to "full" mark and 23-1/2" from seat to "add" mark.
    I don't have the length of the early tube. However, the later tube had a developed length of 22-5/8" end-to-end.
    • Kenneth B.
      • August 31, 1984
      • 2091
      Kenneth------
      THANKS JOE I didn't think so either. I have the early kind but the black plug is missing. My 70 454 with AC length is as you described. My VIN # is 7601
      • Kenn S.
        • September 10, 2009
        • 173
        Mine was built on Feb 21, 1970, is an LS-5 with C60, and missing the black plug. Probalby pretty common. However, Long Island Corvette sells the plugs (red or black) if you hadn't found a suitable replacement. Here's the link:
        I didn't measure it but can...
        -Kenn
        1970 LS-5
        1970 350/300
        1980 L-48
        2004 LS-1
        • Kenneth B.
          • August 31, 1984
          • 2091
          THANKS I am sure mine is correct so I will buy the plug. Makes me wonder if some didn't have one. If it's not too much trouble could you measure yours & tell me what wording is on it? KEN
          • Kenn S.
            • 173
            3 1970 cars...nice. One of my favorite years.
            I imagine they did come with a plug, but after 40 years those puppies likely just fell out. Not much holding them in.
            The overall length is 24 7/8", from the tip to the...boss? The knob that fits into the tube to secure it.
            From the tip it reads: ADD | | FULL, with the line near ADD being 13/16" from the tip and the line near FULL being 1 5/8" from the tip. There is no cross-hatching or holes (later sticks often have these features).
            There is a slight twist starting at about 8" and running to 11", from the tip.
            Hope it's helpful.
            -Kenn
            1970 LS-5
            1970 350/300
            1980 L-48
            2004 LS-1
              • 43263
              Hope it's helpful.
              Kenn------
              Based on the dimensions you mentioned, this dipstick sounds like the 2nd design 1970 Corvette big block dipstick. This dipstick has a red plug.
              • Kenn S.
                • 173
                Thanks, Joe. Since my car is #4429, I'd imagine Ken's would also be second design.
                And thanks for the info...red tip. I'd assumed black.
                -Kenn
                1970 LS-5
                1970 350/300
                1980 L-48
                2004 LS-1
                • Kenneth B.
                  • August 31, 1984
                  • 2091
                  THANKS KENN Believe mine is like yours. Wording is for sure. I will measure to see if it is the same length. My VIN is 7601 so you are right about being the same as yours. Black tip Red tip maybe I should get one of each.
