'93 keys - Time zone - NCRS Discussion Boards
+ More Options
Posts
  • Loren L.
    • April 30, 1976
    • 4104
    The clock in the '93 is set to CST - Reset is quite simple, key on, punch buttons. Mine won't reset at all. Any chance that the key was somehow initially for the CST and it has to be changed?
  • Keith B.
    • September 15, 2014
    • 1591
    Re: '93 keys - Time zone
    a 93 stock radio does not have a time zone feature. if you disconnect the battery and reconnect it will reset it self back to 12:00
    • Loren L.
      • April 30, 1976
      • 4104
      This radio is the Bose cassette/disc combination; owner's manual spells out method of reset which does not work to get to MST.
      • Keith B.
        • 1591
        My 94 Bose radio never set the time for a time zone in the 7 years I owned it Hopefully Pat F will clear this up
        • Jim T.
          • March 1, 1993
          • 5351
          I just use the instructions printed in my 1996 owners manual when I want to change the time. I disconnect my 96's battery neg connection whenever I am not going to be using my 96 and always have to set the clock after reconnecting the neg battery cable if I want a display the correct time. Really an easy function to deal with.
            • 43258
            Loren------
            There is no automatic set or "born with" time zone setting on these radios. It's strictly a manual operation as far as the time setting goes. You can set the radio to any "time zone" you want; it does not know the difference. If your radio can't be set per the owner's manual instructions, my guess is there's something wrong with the radio.
            • Pat F.
              • April 1, 1981
              • 856
              I agree with the above. I have never had a problem in setting my clock to the appropriate time, especially converting back and forth between day light saving time and regualr time. Never took into consideration what time zone NJ is in, although I wonder myself.
              PAT, Central New Jersey and Florida Chapters
              • Leif A.
                • August 31, 1997
                • 3646
                It's the Twillight Zone
                Leif
