Hi all,
I am removing the door posts from a 1957 Corvette. To get them out, I have to remove all the stainless window trim, whiskers, etc. But to do that, I need to remove several screws that hold these items on. Problem is that the window is in the way, so it has to come out. There is a plastic gutter at the bottom of each window on the interior side that makes the assembly way too wide to get the window out with it on, so it almost seems like the bottom of the window would have to be fitted into its lower section while in the door.
So, can any of the hundreds of you out there who have done this give me instructions?
Bob
Bob
