F40- F41 sticker shock - NCRS Discussion Boards
  • Robert N.
    • Today
    I just purchased some F40 shock stickers from a well known supplier, the font is less than 3/8 high (small sticker) I also have a set of the same supplier that I've had for 20 + years and the font is 1/2 high, Which one should I use? and where about on the shock should I place it
  • Larry M.
    • January 1, 1992
    • 2694
    Re: F40- F41 sticker shock
    Robert:
    See this link from a few days ago. An original 1967 shock and label from JohnZ. Hopefully this will help you decide.
    https://www.forums.ncrs.org/showthre...abel-Placement
    There are probably other pics in the archives if you search.
    Larry
    • Robert N.
      • Today
      Thanks Larry, I did a search, but not in the archives, I will do that. Looks like the sticker is the large one? Its has been in a envelope for 20 years, but why wouldn't they sell the right one?
      Thanks again
      Rob O
      • Leif A.
        • August 31, 1997
        • 3630
        Thanks again
        Rob O
        Why don't they do a lot of things the way they should??
        Leif
        • Mark D.
          • June 30, 1988
          • 2151
          Paul Noble reproduces an accurate example.
          Kramden
            • 11643
            I know that for 70-72 the smaller sticker is closer to correct. I suspect that whoever prints them did a "one size fits all" printing for sticker shocks, or used a later year format for a 1967 sticker.
            I do not know if the smaller size is correct for 1967, but am just sharing my observations.
              • 3416
              Hi,
              Here's the location and size of a rear shock broadcast code sticker from my 71 std. suspension.
              I'm thinking the 2 'dots' are the remains of the upper legs of the V. (VS)
