67 Steel Cups in leaf spring & trailing arms - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 305
    According to the 67 judging manual the shallower carry-over 1966 cups were observed on early 67's. My car was built on 12/29/66 and does have the shallow cups.
    Does anyone else know of examples of shallow cups being used thru the end of 1966?
    Steve Gansky
    Newtown, (Bucks County) PA
  • Gary B.
    • February 1, 1997
    • 7069
    Re: 67 Steel Cups in leaf spring & trailing arms
    Steve,
    In my research the latest '67 I've found with the shallow lip on the cups is a car with a build date of Dec 27, 1966. I have 9 other '67s in my database that the early, shallow lip cups, spread out over the Sept - Dec 1966 period.
    What's prompting your question?
    Gary
    • Stephen G.
      • January 1, 2002
      • 305
      Originally posted by Gary Beaupre (28818)
      Steve,
      Gary
      I believe that my car is untouched. I have a crack in the main leaf of the spring and while investigating correct parts for repair I discovered the supposed cut off date for the cups.
      I plan on using the shallow cups as that is what I removed and believe to be correct for my car.
      Steve Gansky
      • Gary B.
        • February 1, 1997
        • 7069
        Steve,
        I'll add your car to my database. Are the cups in your T-arms also the shallow style?
        Gary
        • Stephen G.
          • January 1, 2002
          • 305
          Yes T-arms and spring are shallow.
          1967 Corvette VIN 194377S106952
          Expected date of production 1/13/67
          Built 12/29/66
          Steve Gansky
          • R N.
            • May 31, 2002
            • 640
            Steve...
            My '67 5818 early December 1966 build rear spring has the shallow cups. If you need replacement cups, Gary Beaupre has them. http://garybeaupre.home.comcast.net/...e/Welcome.html
            • Gary B.
              • February 1, 1997
              • 7069
              Built 12/29/66
              Steve,
              Is the build date you list based on the trim tag? And the production date from the dealer report one can get from the NCRS?
              Gary
              • Gary B.
                • February 1, 1997
                • 7069
                Originally posted by R. Kurt Neiman (38038)
                Steve...
                Kurt,
                LIC now sells the shallow cups as well (they list them for '63-'66, which may confuse some owners of early '67s), which LIC says is similar to the original cup geometry. The problem is there are some rear springs that the LIC cups don't fit very well because of the ID of the hole in the main leaf, and/or the thickness of the main leaf. In particular, this can affect the fit and use of the LIC shallow cups in some repro springs. Other than trying the LIC cups, I don't know how to predict beforehand if they will work well or not.
                Gary
                • Stephen G.
                  • January 1, 2002
                  • 305
                  Gary
                  The build date is confirmed by all my docs and the NCRS reports.
                  Steve
                  Steve Gansky
