Help with door glass - NCRS Discussion Boards
  • Gary V.
    • April 15, 2012
    • 76
    I have some light scratches on the driver's side door glass on the outside. It was caused by the outer rubber wiper seal on the door panel over the years, maybe by sand or dirt. They run vertical from top to bottom. The seals have been replaced. I would like to keep the original glass. Is there any way to cover or remove these scratches?
  • Steven B.
    • June 30, 1982
    • 4000
    Re: Help with door glass
    Gary, try cerium oxide. Just mix the powder with water and buff. Glass shops use it and should be able to provide you with a packet. Steve
      • 15616
      We have beat this issue to death. Try a search using "glass scratches" and you will get enough threads to answer your question, including my experience.
        • 3416
        Hi Gary,
        Terry's right that there's been lots of discussion about glass scratches.
        The consensus seems to be that if you can feel the scratch with your fingernail it will take a LOT of polishing to remove it and the result might leave a distortion in the glass that'll be visible at some angles.
        If the mark is more of a 'smear' from rubbing, people report better results.
        Certainly worth a try if it saves your original glass!
        • Gary V.
          • April 15, 2012
          • 76
          Thank you for the input, I will check out those threads, Gary
