Flywheel cover for NOM '64 - NCRS Discussion Boards
  • Ron S.
    • March 29, 2012
    • 14
    MY NOM in 1964 convertible is 18F23065 V0603HN. I do not have a cover for flywheel, which it appears is supposed to be held in by 4 bolts. Is this the part number I need 3789959?? From past info provided this engine is a 1968 327, originally a powerglide, currently it has a 4 speed (only tranny number I can currently see/read is 388 325).
    This car is a driver for me, but would definitely like to have a cover here (some call it a dust cover?).
    Anyone know a source for this part? Thanks.
    Ron
  • Paul D.
    • September 30, 1996
    • 491
    Re: Flywheel cover for NOM '64
    Flywheel cover or dust cover will need to match the bellhousing. Try to get a casting number off your bellhousing and post it here. I am sure we can come up with a number or application from that. Chip.
    • Ron S.
      • March 29, 2012
      • 14
      I thought of including that number after I posted the first time...anyways casting #3914678. And E228, or May 22, 1968.
      Ron
        Ron
        Ron -
        That's the engine block casting number. You should find the (aluminum) bellhousing casting number on the passenger side, just forward of where the transmission attaches.
          • 43290
          Ron
          Ron------
          If the bellhousing casting number is 3840383 or 3858403 you need cover GM #354497
          If the bellhousing casting number is 3899621 or 464697 you need cover GM #3843943
          Where to obtain either one? Any GM dealer can order one for you as both part numbers are currently available from GM.
          • Ron S.
            • March 29, 2012
            • 14
            Here's an update on the numbers, since I was under the lift this afternoon and did my homework for once!
            Trans number: 388 325 then underneath that is: 3088336, followed by General Motors Corporation
            Bellhousing passenger side: GM, then "2" underneath that, then 3840383.
            So the part number for the dust cover is: ??
            Thanks again everyone, Ron
              • 43290
              Ron------
              You need GM #354497. Any GM dealer can order it for you. About 22 bucks, GM list.
              • Ron S.
                • March 29, 2012
                • 14
                Thanks all, I will get it ordered tomorrow.
