66 - Steel Wheels - NCRS Discussion Boards
66 - Steel Wheels
  • Stephen L.
    • August 29, 2007
    • 205
    66 - Steel Wheels
    Are there any reproduction steel wheels that are acceptable for NCRS judging (i.e., that would not have points deducted b/c they are not original)?
    5th post in this thread says only "real deal" will show but that was a 2011 post - https://www.forums.ncrs.org/showthre...6-steel-wheels
    appears new repros are out with the correct "bumps" - do these cut it?
    thanks
  • Stephen L.
    • August 29, 2007
    • 205
    Re: 66 - Steel Wheels
    so here is an ad of the new type of reproduction:
    http://www.amazon.com/1965-1966-Corv.../dp/B00I1YTUH6
    says
    "Not a universal type wheel with shared components from other wheels * All new tooling with exact detail * Has the "nubs" at the valve stem, just like the originals"
    Will this cut it for judging?
    thanks
    • Stephen L.
      • August 29, 2007
      • 205
      anyone?..........
      • Jim S.
        • March 1, 1986
        • 1408
        Sorry Steve. I don't know the answer.
        I can however take several detailed photos of an original 66 wheel for comparrison if it would help .
        Jim
        • Ralph B.
          • July 30, 2008
          • 178
          Steve, I recently purchased a set of reproduction steel wheels from Corvette Specialties Manufacturing last summer and although I can't tell you how they will judge, I can tell you that other than markings, I was unable to tell the difference compared to the one 66 original that I have on hand. I can also tell you that they didn't require excessive weights to achieve good balance (back side only) and the load run out was well within normal acceptable standards. The only thing I did was re-spray the front side only with a gloss black whereas they came with more of a semi-gloss finish IMO which was perfect for the backside. Additionally the 66 hubcaps fit perfectly and they are holding their air pressure perfectly as well. Ralph
          • Joe R.
            • May 31, 2006
            • 1822
            thanks
            Steve,
            I bought a pair at Carlyle for $250.00 each a few years ago. For roughly $100.00 a wheel I think I would rather have originals. But it's not my money we're spending here. What exactly does the Judging Guide say about the steel wheels?
            Joe
            • Stephen L.
              • August 29, 2007
              • 205
              thanks Guys
              Joe - I have ordered the JG so i'll come back with what it says
              thanks again
